Don’t just sit there! Build something!! |
Avoid using the model 741 op-amp, unless you want to challenge your circuit design skills. There are more versatile op-amp models commonly available for the beginner. I recommend the LM324 for DC and low-frequency AC circuits, and the TL082 for AC projects involving audio or higher frequencies.
As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading”. I recommend resistor values between 1 kΩ and 100 kΩ.
Let the electrons themselves give you the answers to your own “practice problems”!
Spend a few moments of time with your class to review some of the “rules” for building circuits before they begin. Discuss these issues with your students in the same Socratic manner you would normally discuss the worksheet questions, rather than simply telling them what they should and should not do. I never cease to be amazed at how poorly students grasp instructions when presented in a typical lecture (instructor monolog) format!
In a common-emitter transistor amplifier circuit, the presence of capacitance between the collector and base terminals - whether intrinsic to the transistor or externally connected - has the effect of turning the amplifier circuit into a low-pass filter, with voltage gain being inversely proportional to frequency:
Explain why this is. Why, exactly, does a capacitance placed in this location affect voltage gain? Hint: it has something to do with negative feedback!
The capacitance provides a path for an AC feedback signal to go from the collector to the base. Given the inverting phase relationship between collector voltage and base voltage, this feedback is degenerative.
Students should realize that this is no hypothetical question. Intrinsic capacitance does indeed exist between the collector and base of a bipolar junction transistor (called the Miller capacitance), and this has a degenerating effect on voltage gain with increasing frequency. If time permits, you may wish to discuss how the common-collector and common-base amplifier configurations naturally avoid this problem.
Which of the following amplifier circuits will be most affected by the base-collector capacitance (shown here as an externally-connected 10 pF capacitor) as frequency increases? Explain why.
The amplifier with the larger collector resistance will be affected more by the feedback capacitance, because its naturally greater voltage gain produces a larger voltage signal to be fed back to the base, for any given level of input signal.
The purpose of this question is to get students to see, on a discrete component level, that for common-emitter amplifier there is a tradeoff between maximum gain and maximum operating frequency. This question foreshadows the concept of Gain-Bandwidth Product (GBW) in operational amplifier circuits.
A common problem encountered in the development of transistor amplifier circuits is unwanted oscillation resulting from parasitic capacitance and inductance forming a positive feedback loop from output to input. Often, these parasitic parameters are quite small (nanohenrys and picofarads), resulting in very high oscillation frequencies.
Another parasitic effect in transistor amplifier circuits is Miller-effect capacitance between the transistor terminals. For common-emitter circuits, the base-collector capacitance (CBC) is especially troublesome because it introduces a feedback path for AC signals to travel directly from the output (collector terminal) to the input (base terminal).
Does this parasitic base-to-collector capacitance encourage or discourage high-frequency oscillations in a common-emitter amplifier circuit? Explain your answer.
The presence of CBC in a common-emitter circuit mitigates high-frequency oscillations.
Note that I chose to use a the word “mitigate” instead of give the answer in more plain English. Part of my reasoning here is to veil the given answer from immediate comprehension so that students must think a bit more. Another part of my reasoning is to force students’ vocabularies to expand.
A student connects a model CA3130 operational amplifier as a voltage follower (or voltage buffer), which is the simplest type of negative feedback op-amp circuit possible:
With the non-inverting input connected to ground (the midpoint in the split 6/-6 volt power supply), the student expects to measure 0 volts DC at the output of the op-amp. This is what the DC voltmeter registers, but when set to AC, it registers substantial AC voltage!
Now this is strange. How can a simple voltage buffer output alternating current when its input is grounded and the power supply is pure DC? Perplexed, the student asks the instructor for help. Öh,” the instructor says, “you need a compensation capacitor between pins 1 and 8.” What does the instructor mean by this cryptic suggestion?
Some op-amps are inherently unstable when operated in negative-feedback mode, and will oscillate on their own unless “phase-compensated” by an external capacitor.
Follow-up question: Are there any applications of an op-amp such as the CA3130 where a compensation capacitor is not needed, or worse yet would be an impediment to successful circuit operation? Hint: some models of op-amp (such as the model 741) have built-in compensation capacitors!
Your students should have researched datasheets for the CA3130 op-amp in search of an answer to this question. Ask them what they found! Which terminals on the CA3130 op-amp do you connect the capacitor between? What size of capacitor is appropriate for this purpose?
Given the fact that some op-amp models come equipped with their own built-in compensation capacitor, what does this tell us about the CA3130’s need for an external capacitor? Why didn’t the manufacturer simply integrate a compensation capacitor into the CA3130’s circuitry as they did with the 741? Or, to phrase the question more directly, ask your students to explain what disadvantage there is in connecting a compensation capacitor to an op-amp.
Some operational amplifiers come equipped with compensation capacitors built inside. The classic 741 design is one such opamp:
Find the compensation capacitor in this schematic diagram, and identify how it provides frequency-dependent negative feedback within the opamp to reduce gain at high frequencies.
Identifying the capacitor is easy: it is the only one in the whole circuit! It couples signal from the collector of Q17, which is an active-loaded common-emitter amplifier, to the base of Q16, which is an emitter-follower driving Q17. Since Q17 inverts the signal applied to Q16‘s base, the feedback is degenerative.
Answering this question will require a review of basic transistor amplifier theory, specifically different configurations of transistor amplifiers and their respective signal phase relationships.
Some operational amplifiers are internally compensated, while others are externally compensated. Explain the difference between the two. Hint: examples of each include the classic LM741 and LM101 operational amplifiers. Research their respective datasheets to see what you find on compensation!
The difference is the physical location of the compensating capacitor, whether it is a part of the integrated circuit or external to it.
Follow-up question: show how an external compensating capacitor may be connected to an opamp such as the LM101.
Ask your students to explain why we might wish to use either type of opamp when building a circuit. In what applications do they think an internally-compensated opamp would be better, and in what applications do they think an externally-compensated opamp would be preferable?
Define “Gain-Bandwidth Product” (GBW) as the term applies to operational amplifiers.
GBW product is a constant value for most operational amplifiers, equal to the open-loop gain of the opamp multiplied by the signal frequency at that gain.
There are other means of defining Gain-Bandwidth Product, so do not be surprised if students present alternative definitions during the discussion time.
Define “Unity-Gain Bandwidth” (B1) as the term applies to operational amplifiers.
Unity-Gain Bandwidth is the frequency at which an operational amplifier’s open-loop voltage gain is equal to 1.
It does not require a great deal of insight to recognize that unity-gain bandwidth (B1) and gain-bandwidth product (GBW) are pretty much the same thing. This would be a good point to bring up (in the form of a question!) for your students if you have already discussed GBW.
Explain the effect that compensation capacitance has on an operational amplifier’s gain-bandwidth product (GBW). Does a larger compensation capacitance yield a greater GBW or a lesser GBW, and why?
The greater the amount of compensation capacitance in an op-amp (either internal, or externally connected), the less the GBW product.
In this question, the really important aspect is not the answer given. What is important here is that students understand what GBW product is, and how it is affected by this thing we call “compensation capacitance” (another topic of research). The goal here is to get students to research these concepts and relate them together, so please do not be satisfied with any student answers that merely restate the answer given here! Ask students to explain what these terms and concepts mean, and to explain why the GBW product decreases with increased Ccomp.
An important AC performance parameter for operational amplifiers is slew rate. Explain what “slew rate” is, and what causes it to be less than optimal for an opamp.
Slew rate is the maximum rate of change of output voltage over time \(\frac{dv}{dt}\)|max that an opamp can muster.
Follow-up question: what would the output waveform of an opamp look like if it were trying to amplify a square wave signal with a frequency and amplitude exceeding the amplifier’s slew rate?
The follow-up question is very important, as it asks students to apply the concept of a maximum [dv/dt] to actual waveshapes. This is often discussed by introductory textbooks, though, so it should not be difficult for students to find good information to help them formulate an answer.
It strikes some students as odd that opamps would have a constant slew rate. That is, when subjected to a step-change input voltage, an opamp’s output voltage would quickly ramp linearly over time, rather than ramp in some other way (such as the inverse exponential curve seen in RC and RL pulse circuits):
Yet, this effect has a definite cause, and it is found in the design of the opamp’s internal circuitry: the voltage multiplication stages within operational amplifier circuits often use active loading for increased voltage gain. An example of active loading may be seen in the following schematic diagram for the classic 741 opamp, where transistor Q9 acts as an active load for transistor Q10, and where transistor Q13 provides an active load for transistor Q17:
Explain how active loading creates the constant slew rate exhibited by operational amplifier circuits such as the 741. What factors account for the linear ramping of voltage over time?
Active loads act as constant-current sources feeding a constant (maximum) current through any capacitances in their way. This leads to constant [dv/dt] rates according to the “Ohm’s Law” equation for capacitors:
Follow-up question: based on what you see here, determine what parameters could be changed within the internal circuitry of an operational amplifier to increase the slew rate.
This question provides good review of fundamental capacitor behavior, and also explains why opamps have slew rates as they do.
Calculate the impedance (in complex number form) “seen” by the AC signal source as it drives the passive integrator circuit on the left, and the active integrator circuit on the right. In both cases, assume that nothing is connected to the Vout terminal:
The most important thing to be learned here is that the opamp “isolates” the signal source from whatever impedance is in the feedback loop, so that the input impedance (in this case, the 10 kΩ resistor) is the only impedance “visible” to that source. This has profound effects on the phase relationship between the output signal and the input signal.
Calculate the phase angle of the current drawn from the AC signal source as it drives the passive integrator circuit on the left, and the active integrator circuit on the right. In both cases, assume that nothing is connected to the Vout terminal:
Θ = 46.7o for the passive integrator current, while Θ = 0o for the active integrator circuit.
by Jake Hertz
by Ikimi .O
by Lianne Frith
