Network Analysis Techniques
DC Branch Current Analysis
Question 1
Don’t just sit there! Build something!! Learning to mathematically analyze circuits requires much study and practice. Typically, students practice by working through lots of sample problems and checking their answers against those provided by the textbook or the instructor. While this is good, there is a much better way.
- Carefully measure and record all component values prior to circuit construction.
- Draw the schematic diagram for the circuit to be analyzed.
- Carefully build this circuit on a breadboard or other convenient medium.
- Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
- Mathematically analyze the circuit, solving for all values of voltage, current, etc.
- Carefully measure those quantities, to verify the accuracy of your analysis.
- If there are any substantial errors (greater than a few percent), carefully check your circuit’s construction against the diagram, then carefully re-calculate the values and re-measure.
Avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading”. I recommend resistors between 1 kΩ and 100 kΩ, unless, of course, the purpose of the circuit is to illustrate the effects of meter loading!
Reveal answerLet the electrons themselves give you the answers to your own “practice problems”!
Notes:It has been my experience that students require much practice with circuit analysis to become proficient. To this end, instructors usually provide their students with lots of practice problems to work through, and provide answers for students to check their work against. While this approach makes students proficient in circuit theory, it fails to fully educate them.
Question 2
A transistor is a semiconductor device that acts as a constant-current regulator. For the sake of analysis, transistors are often considered as constant-current sources:
Suppose we needed to calculate the amount of current drawn from the 6-volt source in this dual-source transistor circuit:
We know the combined currents from the two voltage sources must add up to 5 mA, because Kirchhoff’s Current Law tells us that currents add algebraically at any node. Based on this knowledge, we may label the current through the 6-volt battery as “I”, and the current through the 7.2 volt battery as “5 mA − I”:
Kirchhoff’s Voltage Law tells us that the algebraic sum of voltage drops around any “loop” in a circuit must equal zero. Based on all this data, calculate the value of I:
Hint: simultaneous equations are not needed to solve this problem!
Reveal answerI = 1.9 mA
Notes:I wrote this question in such a way that it mimics branch/mesh current analysis, but with enough added information (namely, the current source’s value) that there is only one variable to solve for. The idea here is to prepare students for realizing why simultaneous equations are necessary in more complex circuits (when the unknowns cannot all be expressed in terms of a single variable).
Question 3
This transistor circuit is powered by two different voltage sources, one that outputs 6 volts, and the other that is variable.
Transistors naturally act as current-regulating devices, and are often analyzed as though they were current sources. Suppose that this transistor happened to be regulating current at a value of 3.5 mA:
How high does the voltage of the variable source have to be adjusted, until no current is drawn from the 6-volt battery?
Reveal answerE = 9.5 V
Notes:The purpose of this question is to get students to apply what they know of basic circuit “laws” (Ohm’s Law, KVL, KCL) to the solution of a single voltage value. As usual, the method of solution is far more valuable than the answer.
If some students are completely confused regarding how to solve for this voltage, suggest that they “plug” the given answer into the circuit and determine currents and voltage drops. What do they notice when they do this? What unusual condition(s) stand out with the variable source at 9.5 volts? Are any of these conditions things they could have (or should have) known prior to knowing the variable source’s voltage, given the condition of “. . . no current [drawn] from the 6-volt battery”?
Question 4
Describe, step-by-step, the steps required to calculate all currents and voltage drops in a DC network using the Branch Current Method.
Reveal answerThere are several textbooks and other references delineating the steps required in this analysis method. I leave the task of researching these steps to you!
Notes:Students may find slight differences between variations of the “Branch Current” method of analysis described in different references. However, these differences are of no consequence.
Question 5
While the “Branch Current” method may be used to analyze an unbalanced bridge circuit, it requires a lot of calculation! In this circuit, determine how many variables are needed to solve for all currents:
Reveal answerSix variables are required to account for all unique values of current in this circuit (I1 through I6).
Challenge question: draw arrows in this circuit depicting these six currents, and write one KCL equation for each node.
Notes:Ask your students to explain why it is difficult to solve for the currents in a circuit like this using the “Branch Current” method. How many equations would be necessary to solve for the values of six variables?
Question 6
Re-draw the circuit shown here into schematic form, and solve for the voltage drops across the two resistors using the “Branch Current” method:
Reveal answer
E2200 Ω = 5.713 V
E4700 Ω = 11.89 V
Notes:Be sure to spend time with your students comparing their different solution strategies. With there being so many combinations of ways to draw branch currents and write equations, it is highly unlikely that all students’ work will be identical. The important lesson here is that different variations still lead to the same (correct) results.
Question 7
Calculate the amount of charging current through battery #1 using the Branch Current method of analysis, given the open-circuit voltages and resistances of the components in this circuit. Disregard any wire resistance:
Reveal answerIbat1 = 1.7248 A
Notes:Ask your students to reveal the equations they used to solve for the current. Their equations will likely differ, but their final answers should be the same!
its soo easy but complicated at the same time
How am I supposed to solve question 7? At first I disregarded any internal resistances of batter/generator and arrived at incorrect answer. Then howewer I “moved” these internal resistances to corresponding fuses and got the right answer. I’m a bit confused. Is this general method? Can we just pretend our voltage sources are ideal in the sense that there is no internal resistance and just attach serially resistor at the + side (with resistance equal to internal resistance of voltage source)?
