AC Electric Circuits
Design Project: Audio Tone Control
  • Question 1
    Suppose you were installing a high-power stereo system in your car, and you wanted to build a simple filter for the “tweeter” (high-frequency) speakers so that no bass (low-frequency) power is wasted in these speakers. Modify the schematic diagram below with a filter circuit of your choice:
    Hint: this only requires a single component per tweeter!
    Reveal answer
  • Question 2
    Examine the following schematic diagram for an audio tone control circuit:
    Determine which potentiometer controls the bass (low frequency) tones and which controls the treble (high frequency) tones, and explain how you made those determinations.
    Reveal answer
  • Question 3
    Note: when testing the frequency response of the tone control circuit, you may need to replace the headphones with a non-inductive resistor of equivalent impedance, and measure Vout across it.
    Reveal answer
  • Question 4
    Note: when testing the frequency response of the tone control circuit, you may need to replace the transformer/speaker assembly with a non-inductive resistor of equivalent impedance, and measure Vout across it.
    Reveal answer
