Discrete Semiconductor Devices and Circuits
PN Junctions
19 questions By Tony R. Kuphaldt
Page 1 of 7 0 of 19 answers revealed (0%)
  • Question 1 of 19
    Don’t just sit there! Build something!!
    1. Carefully measure and record all component values prior to circuit construction, choosing resistor values high enough to make damage to any active components unlikely.
    2. Draw the schematic diagram for the circuit to be analyzed.
    3. Carefully build this circuit on a breadboard or other convenient medium.
    4. Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
    5. Mathematically analyze the circuit, solving for all voltage and current values.
    6. Carefully measure all voltages and currents, to verify the accuracy of your analysis.
    7. If there are any substantial errors (greater than a few percent), carefully check your circuit’s construction against the diagram, then carefully re-calculate the values and re-measure.
    When students are first learning about semiconductor devices, and are most likely to damage them by making improper connections in their circuits, I recommend they experiment with large, high-wattage components (1N4001 rectifying diodes, TO-220 or TO-3 case power transistors, etc.), and using dry-cell battery power sources rather than a benchtop power supply. This decreases the likelihood of component damage.
    As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading” (on the high end) and to avoid transistor burnout (on the low end). I recommend resistors between 1 kΩ and 100 kΩ.
    Reveal answer
  • Question 2 of 19
    The relationship between voltage and current for a PN junction is described by this equation, sometimes referred to as the “diode equation,” or “Shockley’s diode equation” after its discoverer:
    $$I_D= I_S(e^{\frac{qV_D}{NkT}} -1)$$
    Where,
    ID = Current through the PN junction, in amps
    IS = PN junction saturation current, in amps (typically 1 picoamp)
    e = Euler’s number ≈ 2.718281828
    q = Electron unit charge, 1.6 ×10−19 coulombs
    VD = Voltage across the PN junction, in volts
    N = Nonideality coefficient, or emission coefficient (typically between 1 and 2)
    k = Boltzmann’s constant, 1.38 ×10−23
    T = Junction temperature, degrees Kelvin
    At first this equation may seem very daunting, until you realize that there are really only three variables in it: ID, VD, and T. All the other terms are constants. Since in most cases we assume temperature is fairly constant as well, we are really only dealing with two variables: diode current and diode voltage. Based on this realization, re-write the equation as a proportionality rather than an equality, showing how the two variables of diode current and voltage relate:
    ID ∝ . . .
    Based on this simplified equation, what would an I/V graph for a PN junction look like? How does this graph compare against the I/V graph for a resistor?
    Reveal answer
  • Question 3 of 19
    The characteristically colored glow from a gas-discharge electric light is the result of energy emitted by electrons in the gas atoms as they fall from high-level “excited” states back to their natural (“ground”) states. As a general rule of electron behavior, they must absorb energy from an external source to leap into a higher level, and they release that energy upon returning to their original level.
    Given the existence of this phenomenon, what do you suspect might be occurring inside a PN junction as it conducts an electric current?
    Reveal answer
