Discrete Semiconductor Devices and Circuits
Regulated Power Sources
28 questions By Tony R. Kuphaldt
Page 1 of 10 0 of 28 answers revealed (0%)
  • Question 1 of 28
    Don’t just sit there! Build something!!
    1. Carefully measure and record all component values prior to circuit construction, choosing resistor values high enough to make damage to any active components unlikely.
    2. Draw the schematic diagram for the circuit to be analyzed.
    3. Carefully build this circuit on a breadboard or other convenient medium.
    4. Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
    5. Mathematically analyze the circuit, solving for all voltage and current values.
    6. Carefully measure all voltages and currents, to verify the accuracy of your analysis.
    7. If there are any substantial errors (greater than a few percent), carefully check your circuit’s construction against the diagram, then carefully re-calculate the values and re-measure.
    When students are first learning about semiconductor devices, and are most likely to damage them by making improper connections in their circuits, I recommend they experiment with large, high-wattage components (1N4001 rectifying diodes, TO-220 or TO-3 case power transistors, etc.), and using dry-cell battery power sources rather than a benchtop power supply. This decreases the likelihood of component damage.
    As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading” (on the high end) and to avoid transistor burnout (on the low end). I recommend resistors between 1 kΩ and 100 kΩ.
    Reveal answer
  • Question 2 of 28
    Complete the table of output voltages for several given values of input voltage in this common-collector amplifier circuit. Assume that the transistor is a standard silicon NPN unit, with a nominal base-emitter junction forward voltage of 0.7 volts:
    Vin Vout
    0.0 V
    0.5 V
    1.0 V
    1.5 V
    5.0 V
    7.8 V
    Based on the values you calculate, explain why the common-collector circuit configuration is often referred to as an emitter follower.
    Reveal answer
  • Question 3 of 28
    Complete the table of output voltages, output currents, and input currents for several given values of input voltage in this common-collector amplifier circuit. Assume that the transistor is a standard silicon NPN unit, with a nominal base-emitter junction forward voltage of 0.7 volts:
    Vin Vout Iin Iout
    0.0 V
    0.4 V
    1.2 V
    3.4 V
    7.1 V
    10.8 V
    Calculate the voltage and current gains of this circuit from the numerical values in the table:
    $$A_V= \frac{\triangle V_{out}}{\triangle V_{in}}=$$
    $$A_I= \frac{\triangle I_{out}}{\triangle I_{in}}=$$
    Reveal answer
