Molex Mini-Fit Sigma Sealed Power Connectors | Tech Specs
New Product September 29, 2020 by TTI, Inc
Molex Mini-Fit Sigma Sealed Power Connectors protect against water, foam, and dust debris, keeping your power connections safe in whatever, appliance, or industrial machinery you put it on.
The connectors consist of a rubber cap that mounts to the back of the housing and is tested to IP51 requirements. The housings accept standard Mini-Fit TPA2 terminals, have supports for optional TPA inserts to keep terminals securely seated, and they have panel mount ears to keep the connector stable when mounted to a panel. Mini-Fit Sigma Sealed Power Connectors are keyed and polarized to mate with standard Mini-Fit Power Connectors.
They’re available with up to 14 circuits on a 4.2 millimeter pitch and can carry up to 13 amps per circuit.
  • Rubber sealing cap tested to IP51 requirements
  • Uses traditional Mini-Fit TPA2 terminals and has TPA supports for optional TPA inserts
  • Panel mount ears provide safe and stable panel mounting
  • Keying and polarization for accurate mating with standard Mini-Fit Power Connectors
  • 8 to 14 circuits on 4.20mm pitch
  • Up to 13A per circuit
Click here for more information.
