Molex Brad Quick-Change Connectors | Tech Specs
New Product September 05, 2019 by TTI, Inc
Equipment in harsh environments, like the high temperatures of steel factories, caustic humidity of paper production, and the harsh chemical wash-down of food processing equipment, needs to be toughly built. The Molex Brad Quick-Change connectors are built to deliver years of uninterrupted performance in a range of harsh environments.
These Quick-Change connectors are sealed to an IP67 rating to keep water out, and they have a nylon coupling nut and receptacle shell so there’s no hardware corrosion. The connectors are available with 2, 3, or 4 poles and are rated for up to 30 amps, allowing them to be used with motors and other high amperage devices in a wide variety of applications.
Molex Brad Quick-Change Connectors are bright yellow for enhanced visibility and are keyed to reduced the chance of mis-mating.
  • Built for years of uninterrupted performance in extreme environments
  • IP67 sealed to prevent water entry
  • Standard nylon coupling nut and receptacle shell eliminates hardware corrosion
  • Available in 2, 3, and 4 pole configurations
  • Rated up to 30.0A
  • Safety yellow color for enhanced visibility
More Information
