Molex 2.5mm Board-In Connector | Tech Specs
New Product December 10, 2020 by TTI, Inc
Molex 2.5 millimeter Board-in connectors are a one-piece connector that is soldered directly to the PCB to make a cost effective, space-saving and reliable connection.
Housings are available in both vertical and right-angle versions with 2 to 6 positions on a 2.5 millimeter pitch and can be assembled with vertical or right-angle crimp terminals for application flexibility. The connectors feature an improved terminal pin position that makes assembly fast and efficient.
Molex 2.5 millimeter Board-in connectors are rated for up to 125 volts and 3 amps and have an operating temperature of up to 125 degrees Celsius.
  • One-piece molded housing: cost-effective, space-saving, and reliable
  • Positions: 2 to 6, right-angle or vertical
  • Improved terminal pin position improves assembly efficiency
  • Applicable wire: FLRY 0.22mm2, 0.35mm2
  • Electrical ratings (max): 125V, 3.0A
  • Operating Temperature: -40°C to +125°C
Click here for more information.
