Murata Electronics NFG Common Mode Noise Filter | New Product Brief
New Product December 10, 2020 by Mouser
Murata Electronics NFG Common Mode Noise Filters provide common-mode filtering in a tiny package ideal for portable devices, such as laptops, smartphones, and digital cameras.
The NFG series is compatible with the MIPI C-PHY standard, which provides a high-speed physical layer for a wide range of MIPI CSI-2 and MIPI DSI-2 interfaces. NFG filters provide a common mode insertion loss ranging from 19 to 29 dB, with maximum filtering between 1 gigahertz and 3 gigahertz.
They’re also designed to match line impedance in MIPI C-PHY applications, eliminating the need for matching circuits. The devices offer 3 circuits in a small package with tight tolerances, making them ideal for use in compact portable devices.
Murata Electronics NFG filters are rated for 5 volts and up to 100 milliamps and for operation from negative 40 to positive 85 degrees Celsius.
  • Compatible with high speed, MIPI C-PHY standard
  • Common Mode Insertion Loss: 19dB to 29dB
    • Maximum filtering from 1.0GHz to 3.0GHz
  • Designed to match MIPI C-PHY line impedance
    • 25Ω common mode impedance
  • Compact: 0.90mm x 0.68mm x 0.40mm
    • Tolerance: ±0.05mm
  • Ratings:
    • 5V, 100mA
    • -40°C to +85°C
