STMicroelectronics TSB712A Precision Amplifier | New Product Brief
STMicroelectronics’ TSB712A is a 6MHz precision op-amp for use in a variety of applications, including current sensing, motor control, process control, sensors, and instrumentation.
New Product January 23, 2019 by Mouser
STMicroelectronics’ TSB712A is a 6MHz precision op-amp for use in a variety of applications, including current sensing, motor control, process control, sensors, and instrumentation.  The TSB712A operates from a wide 2.7V to 36V supply for flexibility and use across multiple designs, and it offers rail-to-rail input and output with a 3V/µs slew rate. The op-amps are designed for precise measurements, with a 300µV max offset at 25°C and 580µV over the entire -40°C to +125°C operating range.  The low offset, combined with low noise and an integrated EMI filter ensure precision even with low amplitude signals. The TSB712A is available in standard SO8 and MiniSO8 packages, and automotive grade variants are available.
  • Gain bandwidth product: 6MHz
  • Supply voltage: +2.7V to +36V or ±1.35V to ±18V
  • Rail-to-rail input and output
  • Slew rate: 3V/µs
  • 300µV max offset (25°C) and 2.8µV/°C offset drift
  • Low noise: 12 nV/√Hz
More Information
