TE Connectivity MS5840 Pressure Sensor | Tech Specs
New Product January 15, 2020 by TTI, Inc
The MS5840-02BA is an ultra-compact pressure sensor designed for altimeter and barometer applications with a ceramic-metal package measuring 1.7 millimeters tall.
Inside is a high-linearity MEMS pressure sensor and a 24-bit ADC with factory-calibrated coefficients, providing pressure and temperature values with high resolution and accuracy. It utilizes a gasket or O-ring to provide a water-resistant seal. The stainless steel lid is filled with a black silicone gel protecting the sensor against water and contaminants.
It’s also designed with integrated shielding and an option for chlorine-resistance. The MS5840-02BA operates from 300 to 1200 millibar and negative 20 to positive 85 degrees Celsius.
It draws just 0.6 microamps from a 1.5 to 3.6 volt supply, and current consumption drops below 0.1 microamps in standby.
  • Ceramic - metal package, 3.3 x 3.3 x 1.7mm
  • High resolution: 13cm of air at sea level
  • Black silicone gel protects against water and contaminants
  • Integrated shielding and chlorine resistant option
  • Operating range: 300mbar to 1200mbar, -20°C to +85°C
  • Power supply: 1.5V to 3.6V, 0.6µA (standby ≤ 0.1 µA at 25°C)
More Information
