Partners in Tech: Design Wins From Medical Delivery Drones to Space Chips
NXP, Würth Elektronik, and Arteris, along with their design partners, release new projects with smarter drones, faster IoT design, and more resilient space systems.
News November 18, 2025 by Joshua Tidwell
Across the tech industry, progress often comes from collaboration rather than competition. These companies are pushing current technology to tackle some unique challenges, from drones that can deliver medicine directly to apartment windows to chips that can survive deep space. These partnerships are creating systems that can adapt, communicate, and perform where older technology struggled.
Recent collaborations from NXP and Jedsy, Würth Elektronik and Nordic Semiconductor, and Arteris and NanoXplore show how shared development can lead to real-world progress. Each one addresses a different challenge: improving navigation precision, expanding flexibility in wireless IoT design, and ensuring reliable computing under extreme conditions.
NXP and Jedsy’s UWB Medical Drones
The Jedsy X medical drone is taking flight to solve one of delivery’s hardest challenges: the landing zone. Instead of landing in open areas, it can pull up directly to a window or balcony to drop off supplies. That level of control depends on exact positioning, which is handled by NXP’s Trimension SR150 ultra-wideband (UWB) chipset.
Jedsy X medical delivery drone uses NXP’s Trimension UWB tech
A Jedsy X medical delivery drone uses NXP’s Trimension UWB tech to pinpoint landing spots with centimeter-level accuracy. Image used courtesy of NXP
The UWB works by measuring the time it takes for radio pulses to travel between devices, giving the system a highly accurate sense of distance and direction. In the Jedsy X, the chip allows the drone to map its surroundings in three dimensions and maintain precise flight paths even when GPS is unreliable, such as near tall buildings or inside dense city blocks. The SR150 combines this distance data with short-range radar and angle-of-arrival measurements to track both position and motion in real time.
The same sensing capability can be adapted for other medical and industrial uses, such as locating equipment inside hospitals, monitoring movement in assisted-care facilities, or verifying access in secure environments. This collaborative effort shows how a communication standard first used in consumer electronics is now being applied to systems that depend on accuracy and safety rather than convenience.
Nordic Semiconductor and Würth Elektronik’s Dual Wireless Modules
IoT developers often have to choose between flexibility and speed: either build firmware from scratch for full control or use a pre-configured module to get to market faster. Würth Elektronik’s Ophelia-IV and Proteus-IV modules, powered by Nordic Semiconductor’s nRF54L15 SoC, offer both paths.
Würth Elektronik’s Proteus-IV and Ophelia-IV modules
Würth Elektronik’s Proteus-IV and Ophelia-IV modules both measure 8 mm x 12 mm x 2.3 mm. Image used courtesy of Nordic Semiconductor
While both modules share the same 8 mm x 12 mm x 2.3 mm form factor and hardware base, they serve different roles. The Ophelia-IV is aimed at developers who want control over firmware from the start. It provides 29 GPIOs and comes unprogrammed, ready for projects built with the nRF Connect SDK and Zephyr RTOS. The Proteus-IV is meant for quick deployment, and ships with ready-to-use Bluetooth LE firmware.
Each module runs on the nRF54L15 SoC, which pairs a 128-MHz Arm Cortex-M33 CPU with a RISC-V co-processor and a multiprotocol 2.4-GHz radio. With support for Bluetooth LE, Matter, Thread, Zigbee, and IEEE 802.15.4, it gives developers room to experiment and expand without changing hardware designs.
Arteris and NanoXplore’s Space Collaboration
NanoXplore, known for its radiation-hardened FPGA technology, is integrating Arteris’ FlexGen network-on-chip IP to simplify how data moves inside its space-grade devices. Instead of manually defining signal paths between cores and memory, FlexGen uses automation to arrange those connections more efficiently. That tighter layout helps cut down on signal delay and power use, two issues that become critical when electronics are exposed to radiation and temperature extremes.
Fig. 1 Smart NoC generation giving a 10x productivity gain over manual NoC configuration and optimization.
NanoXplore will be utilizing Arteris’ FlexGen network-on-chip IP to automate internal data routing in its radiation-hardened FPGAs. Image used courtesy of Arteris
By using FlexGen, NanoXplore can deliver faster, more efficient SoC FPGA designs without increasing silicon area or power draw. This kind of architecture-level optimization helps meet the growing demand for higher data throughput in satellite and defense systems, where hardware must balance computational power with strict power and thermal limits.
Small Team Ups Yield Big Progress
Each collaboration shows how progress often comes from refining what already works instead of rebuilding from zero. By combining different areas of expertise, these teams have managed to make drones land precisely, simplify wireless development, and improve computing resilience in space. When engineering groups share tools and ideas, the results tend to reach the field faster and perform better where it actually matters.
