How to Make an IoT Teapot | The Gentleman Maker
No longer will you have to get off the couch or out of your warm bed to get the pot brewed!
Project February 28, 2018 by Robin Mitchell
In this episode of The Gentleman Maker, we will create every British person’s dream: an IoT teapot. No longer will you have to get off the couch to get the pot brewed! Use your smartphone to put the kettle on!
IoT Teapot BOM
  • ESP8266 Wi-Fi D1 R2 dev board
  • 2 x 12V 100W travel cup boilers (R3, R6)
  • A ceramic teapot
  • 1 x ATX power supply
  • 2 x 10A @ 30V relays (RL1, RL2)
  • Thermistor (TH1)
  • 100R resistor (R2)
  • 1K resistors (R1, R5)
  • 5.6K resistor (R4)
  • 2N3904 transistors (Q1, Q2)
Note: The video suggests that the base resistors should be 5.6K, but they should, in fact, be 1K!
The Schematic
When the ESP8266 detects a request for tea, it starts by switching on its output D5 (which has been labeled as HeaterOn). When this happens, Q1 and Q2 are switched on, which energizes relay coils RY1 and RY2. This energizing of the coil creates a magnetic field, which attracts a small mechanical lever inside the relays. This completes the heater circuits and turns on the heater elements (HEATER). Then the water begins to boil.
The thermistor R2 is a potential divider circuit, with R4 such that the voltage across the thermistor is inversely proportional to its temperature. In other words, as the water temperature increases, so does the outside of the pot, and, therefore, the voltage across R2 (the thermistor) decreases. This voltage is measured by the ESP8266 (via pin A0), which is used for analog measurement readings, and a series protection resistor (R5) sits between the divider and the analog input pin. Eventually, the thermistor voltage will cross a threshold, which will result in the ESP8266 turning off both transistors, Q1 and Q2. This will de-energize the two relays and, thus, disable the heaters.
You can check out the full schematic here!
Creating the Teapot
When putting the heating elements inside the teapot, it’s best to go through the lid instead of trying to drill a hole in the bottom. Originally, I was going to use a small hole on the bottom, feed the wires through, and then seal it with two-part epoxy, but there are two potential issues with this:
  1. The two-part epoxy may not be food-safe.
  2. Heat expansion may cause a leak.
The thermistor was not mounted on the circuit board. Instead, I connected it to a long pair of wires so the thermistor could be attached to the OUTSIDE of the teapot instead of the inside. Again, this is due to health and safety concerns, especially considering that I use lead solder. The idea of drinking lead-infused water is … wait for it … not my cup of tea!
So, instead, I attached the thermistor to the underside of the pot and secured it in place with some masking tape; however, this could, in fact, be glued on. Then, to determine the cut-off temperature, you can simply fill the pot with boiling water and wait for the pot to heat up. At this point, you can either obtain an ADC reading on the MicroPython or measure the voltage across the thermistor.
The Website
Most free hosting sites allow PHP files, so this project should work on an unpaid site. However, I paid for web service through AwardSpace, bought my own domain, and created a subdomain just for this project (iot.websitename.co.uk). While the website shown in this project has many files, they are mainly for CSS styling and layout. The only files that really matter are index.php (the main entry point), indexContent.php (which holds our buttons), submit.php (which we send commands to), and tea.html (which holds the teapot state).
Pressing the “Tea On” button will invoke the submit.php page and create an external file called “tea.html” with the word “#Tea On#”. The text is surrounded by hashtags, so we can pass the entire HTTP message (which also includes header information) into a string split, where the splitting element is “#”. In the end, the first split is the header and some other information, the second element is the tea state, and the third element is the rest of the HTML file.
The Python Code
The code for the teapot is incredibly simple. It consists of three main functions:
  • Wi-Fi connection
  • HTTP GET message
  • HTTP POST message
The Wi-Fi connection script is called on bootup and it constantly tries to connect to the specified network. The system then enters a loop where it constantly calls HTTP GET to retrieve the teapot status.
Once the tea.html file has changed to “Tea On”, the code enters a loop where the elements are switched on and constant analog readings from the thermistor are taken. Once the water reaches the designated temperature, the code turns off the elements and sends an HTTP POST message, informing the website to set the tea state to “Tea Done”. You can see the activity on the MicroPython as it runs if you plug it into a computer and open a terminal window!
Now you're ready to put together your kettle and make a cup of tea! Let us know about your tea-related electronics adventures in the comments below.
  • Chantelle Dubois March 02, 2018
    My life will never be the same again after watching this video! I’m not English but I do drink a lot of tea and now I know what my next project is…
  • M
    MisterBill2 March 24, 2018
    While I was in the U.K. I did observe teapots in the homes of my hosts, as well as in a store. Without exception these teapots were powered by the standard British 230 volts line system, and those that I observed in operation heated quite rapidly. I doubt that a 12 volt heater would do as well, given that the 12 volt outputs from the ATX power supply usually deliver less than 100 watts, and even that high powered 5 volt output is only a very few hundred watts.
    In addition, while there may be more roundabout ways to switch on a teapot, I am hard put to think of them. Also, heating elements should be either brazed or welded, never epoxied or attached with any sort of adhesive.
  • Cool project
