Basic Electricity
Basic Circuit Troubleshooting
  • Question 1
    Determine if the light bulb will de-energize for each of the following breaks in the circuit. Consider just one break at a time:
    Choose one option for each point:
    • A: de-energize / no effect
    • B: de-energize / no effect
    • C: de-energize / no effect
    • D: de-energize / no effect
    • E: de-energize / no effect
    • F: de-energize / no effect
    Reveal answer
  • Question 2
    Examine the following illustration of a simple battery-switch-lamp circuit, connected together using screw-terminal blocks, each connection point on each terminal block identified by a unique number:
    Determine whether or not voltage should be present between the following pairs of terminal block points with the switch in the ON position:
    • Points 1 and 5:
    • Points 6 and 7:
    • Points 4 and 10:
    • Points 9 and 12:
    • Points 6 and 12:
    • Points 9 and 10:
    • Points 4 and 7:
    Now, determine whether or not voltage should be present between the following pairs of terminal block points with the switch in the OFF position:
    • Points 1 and 5:
    • Points 6 and 7:
    • Points 4 and 10:
    • Points 9 and 12:
    • Points 6 and 12:
    • Points 9 and 10:
    • Points 4 and 7:
    Reveal answer
  • Question 3
    The following battery-switch-lamp circuit has a problem. Over time, corrosion has developed between the wire end and the screw terminal labeled “4” on the upper side of the top terminal block. This corroded connection now has a high resistance instead of a low resistance as it should. As a result, the light bulb does not energize when the switch is turned ON:
    Taking voltage measurements with a voltmeter, how do you think this corrosion problem will reveal itself with the switch on the ON position? In other words, which voltage measurement in this circuit (i.e. between which pair or pairs of terminal block points) will be unusual as a result of the bad connection at point #4, and approximately how much voltage should that measurement be?
    Reveal answer
  • Question 4
    In this battery-switch-lamp circuit, the metal filament wire inside the lamp has burned up, so that it no longer forms an electrically continuous connection. In other words, the filament has failed “open.”
    Of course, this means the lamp will not turn on, no matter what is done with the switch. It also means that most of the voltage measurements taken in the circuit will be the same as with a properly operating circuit. There is, however, one voltage measurement which will be different in the circuit with the burned-out filament than in a properly working circuit. Identify what pair or pairs of terminal block points this different voltage will be measured between, what switch state (ON or OFF) it will appear in, and what this different voltage measurement will actually be relative to the battery voltage.
    Reveal answer
  • Question 5
    In this circuit, where would you expect to measure full battery voltage (between what pairs of test points)?
    Reveal answer
  • Question 6
    In this circuit, where would you not expect to measure significant voltage (between what pairs of test points)?
    Reveal answer
  • Question 7
    Suppose this battery and light bulb circuit failed to work. Using nothing but a voltmeter, how would you check the circuit to determine where the problem is located? Note: the letters indicate “test points” along the wiring where you may probe with the circuit with your voltmeter.
    Reveal answer
  • Question 8
    Suppose this battery and light bulb circuit failed to work:
    Using a voltmeter, a technician measures full battery voltage between the points C and H. What does this single measurement indicate about the condition of the circuit? Be as specific as you can.
    Reveal answer
  • Question 9
    Using a voltmeter, a technician measures full battery voltage between the points C and H. The result of this single measurement indicates which half of the circuit there is a definite problem in. What would you recommend as the next voltmeter measurement to take in troubleshooting the circuit, following the same “divide in half” strategy?
    Reveal answer
  • Question 10
    Using a voltmeter, a technician measures 0 volts between the points C and H. What does this single measurement indicate about the condition of the circuit? Be as specific as you can.
    Reveal answer
  • Question 11
    Using a voltmeter, a technician measures 0 volts between the points C and H. The result of this single measurement indicates which half of the circuit there is a definite problem in. What would you recommend as the next voltmeter measurement to take in troubleshooting the circuit, following the same “divide in half” strategy?
    Reveal answer
  • Question 12
    Using nothing but a voltmeter, a technician measures voltage between the following sets of points:
    • Between A and C: 0 volts
    • Between D and G: 12 volts
    • Between E and J: 0 volts
    • Between B and E: 12 volts
    From these voltage measurements, what can you tell about the condition of the battery, wiring, and light bulb? Be as specific as you can.
    Challenge question: identify which of the four measurement are unnecessary in determining the precise location of the fault in this circuit.
    Reveal answer
  • Question 13
    The circuit shown here is called a “bridge rectifier,” and its purpose is to convert alternating current (from the “power-supply” unit) into direct current. Suppose you were instructed to check the continuity of the switch (SW1) mounted on the printed circuit board. What would be a fast and effective way of testing this switch’s continuity (ideally, without removing the switch from the circuit board)?
    Reveal answer
  • Question 14
    Identify which of these are true statements:
    1. Between two points that are electrically common to each other, there is guaranteed to be zero voltage.
    2. If zero voltage is measured between two points, those points must be electrically common to each other.
    3. Between two points that are not electrically common to each other, there is guaranteed to be voltage.
    4. If voltage is measured between two points, those points must not be electrically common to each other.
    Reveal answer
  • Question 15
    Suppose a technician were troubleshooting the following circuit, whose light bulb refused to light up:
    The technician records their steps on a piece of paper divided into two columns: Observations, and Conclusions, drawing a horizontal line underneath each conclusion after it is made:
    Critique this technician’s troubleshooting job, noting any errors or unnecessary steps.
    Reveal answer
  • Question 16
    The following circuit has a problem. When the switch is closed, the lamp does not turn on:
    Identify which of these hypothetical faults could account for this problem, and which could not account for the problem. In other words, which of these faults are possible, and which are not possible, given the symptoms exhibited by the circuit? Consider each of these hypothetical faults one at a time (no multiple, simultaneous faults):
    • Light bulb filament failed open
    • Switch failed shorted
    • Switch failed open
    Reveal answer
  • Question 17
    The following circuit has a problem. Switch #1 is able to control lamp #1, but lamp #2 never comes on no matter what is done with switch #2:
    • Battery is dead
    • Switch #2 failed open
    • Switch #2 failed shorted
    • Switch #1 failed open
    • Switch #1 failed shorted
    • Open wire between test points 1 and 2 (between TP1 and TP2)
    • Open wire between test points 5 and 6 (between TP5 and TP6)
    Reveal answer
  • Question 18
    The following circuit has a problem. Switch #2 is able to control lamp #2, but lamp #1 never comes on no matter what is done with switch #1:
    • Battery is dead
    • Lamp #1 filament failed open
    • Lamp #2 filament failed open
    • Open wire between test points 4 and 5 (between TP4 and TP5)
    Reveal answer
  • Bins July 14, 2022
    May I know the people who created these examples? through APA 6 or 7 format of citation?
  • pnwinside February 23, 2023
    Some good brain teasers. It was nice getting my head wrapped around the idea of getting voltage on a common side of a circuit (due to a break on that side) 🤠
