Discrete Semiconductor Devices and Circuits
Conventional Transistor Overview and Special Transistors
  • Question 1
    A microcontroller is a specialized type of digital computer used to provide automatic sequencing or control of a system. Microcontrollers differ from ordinary digital computers in being very small (typically a single integrated circuit chip), with several dedicated pins for input and/or output of digital signals, and limited memory. Instructions programmed into the microcontroller’s memory tell it how to react to input conditions, and what types of signals to send to the outputs.
    The simplest type of signal “understood” by a microcontroller is a discrete voltage level: either “high” (approximately V) or “low” (approximately ground potential) measured at a specified pin on the chip. Transistors internal to the microcontroller produce these “high” and “low” signals at the output pins, their actions being modeled by SPDT switches for simplicity’s sake:
    It does not require much imagination to visualize how microcontrollers may be used in practical systems: turning external devices on and off according to input pin and/or time conditions. Examples include appliance control (oven timers, temperature controllers), automotive engine control (fuel injectors, ignition timing, self-diagnostic systems), and robotics (servo actuation, sensory processing, navigation logic). In fact, if you live in an industrialized nation, you probably own several dozen microcontrollers (embedded in various devices) and don’t even realize it!
    One of the practical limitations of microcontrollers, though, is their low output drive current limit: typically less than 50 mA. The miniaturization of the microcontroller’s internal circuitry prohibits the inclusion of output transistors having any significant power rating, and so we must connect transistors to the output pins in order to drive any significant load(s).
    Suppose we wished to have a microcontroller drive a DC-actuated solenoid valve requiring 2 amps of current at 24 volts. A simple solution would be to use an NPN transistor as an “interposing” device between the microcontroller and the solenoid valve like this:
    Unfortunately, a single BJT does not provide enough current gain to actuate the solenoid. With 20 mA of output current from the microcontroller pin and a β of only 25 (typical for a power transistor), this only provides about 500 mA to the solenoid coil.
    A solution to this problem involves two bipolar transistors in a Darlington pair arrangement:
    However, there is another solution yet - replace the single BJT with a single MOSFET, which requires no drive current at all. Show how this may be done:
    Reveal answer
  • Question 2
    Examine the following transistor symbol:
    Identify the following:
    Type of transistor (BJT, JFET, or MOSFET)
    Semiconductor doping (NPN, PNP ; N-channel, P-channel)
    Identification of all 3 terminals (Base, Collector, Emitter ; Gate, Drain, Source)
    Direction of each terminal’s current for proper transistor operation (be sure to note whether you are using conventional flow or electron flow notation. If current direction is unimportant, or if there is no current at all, be sure to say so!)
    Reveal answer
  • Question 3
    Reveal answer
  • Question 4
    Reveal answer
  • Question 5
    Reveal answer
  • Question 6
    Reveal answer
  • Question 7
    Reveal answer
  • Question 8
    Reveal answer
  • Question 9
    Reveal answer
  • Question 10
    Identify what each type of transistor is (MOSFET, JFET, or BJT; N-channel, P-channel, NPN, or PNP, E-type or D-type), and what must be connected to the controlling terminal of each transistor (base or gate) to turn each one on so that the light bulb energizes:
    Reveal answer
  • Question 11
    Reveal answer
  • Question 12
    Shown here is the schematic diagram for a simple automotive ignition system, to produce pulses of high voltage sufficient to energize spark plugs in an engine:
    An engineer decides to replace the BJT with a MOSFET, and arrives at the following circuit design:
    Explain how this revised circuit works. When does the MOSFET conduct current, when the point contacts are open or closed? How does this compare to the working of the previous (BJT) circuit? What purpose does the 10 kΩ resistor serve?
    Reveal answer
  • Question 13
    In this system, the voltage output of a digital timing circuit controls the charging and discharging of a resistor-capacitor network. The inner workings of the digital timing circuit are hidden for simplicity’s sake, but we may model it as a two-position switch, outputting either a “high” voltage signal (full supply voltage) or a “low” voltage signal (ground potential) at regular intervals:
    First, identify what signal level from the digital circuit (“high” or “low”) causes the capacitor to charge, and what level causes it to discharge. Then, replace the BJT with a suitable MOSFET to accomplish the exact same timing function:
    Reveal answer
