Digital Circuits
High-Reliability Circuits
9 questions By Tony R. Kuphaldt
Page 1 of 3 0 of 9 answers revealed (0%)
  • Question 1 of 9
    Don’t just sit there! Build something!!
    Learning to analyze relay circuits requires much study and practice. Typically, students practice by working through lots of sample problems and checking their answers against those provided by the textbook or the instructor. While this is good, there is a much better way.
    1. Draw the schematic diagram for the relay circuit to be analyzed.
    2. Carefully build this circuit on a breadboard or other convenient medium.
    3. Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
    4. Analyze the circuit, determining all logic states for given input conditions.
    5. Carefully measure those logic states, to verify the accuracy of your analysis.
    6. If there are any errors, carefully check your circuit’s construction against the diagram, then carefully re-analyze the circuit and re-measure.
    Always be sure that the power supply voltage levels are within specification for the relay coils you plan to use. I recommend using PC-board relays with coil voltages suitable for single-battery power (6 volt is good). Relay coils draw quite a bit more current than, say, semiconductor logic gates, so use a “lantern” size 6 volt battery for adequate operating life.
    Reveal answer
  • Question 2 of 9
    The equation relating probability of continued performance for a component or a system versus time may be expressed as follows:
    x = e−t / m
    Where,
    x = Probability (a number between 0 and 1, inclusive)
    e = Euler’s constant ( ≈ 2.7182818)
    t = Time of continuous operation
    m = Mean Time Between Failure of the component or system
    The unit of time for both t and m must be the same. That is, if t is measured in years, then m must also be expressed in years or else the equation will give very misleading answers.
    Suppose, though, we were given m in years, and the operating time t in days. Substitute the relationship td = 365 ty into the reliability equation so that we will have a new equation that can take t in days (td) and m in years, and still provide the correct answer.
    Reveal answer
  • Question 3 of 9
    Explain what the following statement means, with regard to the design of electronic circuits:
    Faults are inevitable, but failure is not.
    Specifically, what does this philosophy mean for your career as an electronics professional, entrusted with the installation, maintenance, and possibly design of complex systems?
    Reveal answer
Related Tools:
