Analog Integrated Circuits
Nonlinear OpAmp Circuits
17 questions By Tony R. Kuphaldt
Page 1 of 6 0 of 17 answers revealed (0%)
  • Question 1 of 17
    Don’t just sit there! Build something!!
    1. Carefully measure and record all component values prior to circuit construction.
    2. Draw the schematic diagram for the circuit to be analyzed.
    3. Carefully build this circuit on a breadboard or other convenient medium.
    4. Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
    5. Mathematically analyze the circuit, solving for all voltage and current values.
    6. Carefully measure all voltages and currents, to verify the accuracy of your analysis.
    7. If there are any substantial errors (greater than a few percent), carefully check your circuit’s construction against the diagram, then carefully re-calculate the values and re-measure.
    Avoid using the model 741 op-amp, unless you want to challenge your circuit design skills. There are more versatile op-amp models commonly available for the beginner. I recommend the LM324 for DC and low-frequency AC circuits, and the TL082 for AC projects involving audio or higher frequencies.
    As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading”. I recommend resistor values between 1 kΩ and 100 kΩ.
    Reveal answer
  • Question 2 of 17
    We know that an opamp connected to a voltage divider with a voltage division ratio of \(\frac{1}{2}\) will have an overall voltage gain of 2, and that the same circuit with a voltage division ratio of \(\frac{2}{3}\) will have an overall voltage gain of 1.5, or \(\frac{3}{2}\):
    There is definitely a mathematical pattern at work in these non-inverting opamp circuits: the overall voltage gain of the circuit is the mathematical inverse of the feedback network’s voltage gain.
    Building on this concept, what do you think would be the overall function of the following opamp circuits?
    Reveal answer
  • Question 3 of 17
    The relationship between voltage and current for a PN junction is described by this equation, sometimes referred to as the “diode equation,” or “Shockley’s diode equation” after its discoverer:
    ID = IS (e[(qVD)/NkT] − 1)
    Where,
    ID = Current through the PN junction, in amps
    IS = PN junction saturation current, in amps (typically 1 picoamp)
    e = Euler’s number ≈ 2.718281828
    q = Electron unit charge, 1.6 ×10−19 coulombs
    VD = Voltage across the PN junction, in volts
    N = Nonideality coefficient, or emission coefficient (typically between 1 and 2)
    k = Boltzmann’s constant, 1.38 ×10−23
    T = Junction temperature, degrees Kelvin
    At first this equation may seem very daunting, until you realize that there are really only three variables in it: ID, VD, and T. All the other terms are constants. Since in most cases we assume temperature is fairly constant as well, we are really only dealing with two variables: diode current and diode voltage. Based on this realization, re-write the equation as a proportionality rather than an equality, showing how the two variables of diode current and voltage relate:
    ID. . .
    Based on this simplified equation, what would an I/V graph for a PN junction look like? How does this graph compare against the I/V graph for a resistor?
    Reveal answer
