Analog Integrated Circuits
Op-amp Circuits
Question 1
Don’t just sit there! Build something!! Learning to mathematically analyze circuits requires much study and practice. Typically, students practice by working through lots of sample problems and checking their answers against those provided by the textbook or the instructor. While this is good, there is a much better way.
- Carefully measure and record all component values prior to circuit construction.
- Draw the schematic diagram for the circuit to be analyzed.
- Carefully build this circuit on a breadboard or other convenient medium.
- Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
- Mathematically analyze the circuit, solving for all voltage and current values.
- Carefully measure all voltages and currents, to verify the accuracy of your analysis.
- If there are any substantial errors (greater than a few percent), carefully check your circuit’s construction against the diagram, then carefully re-calculate the values and re-measure.
Avoid using the model 741 op-amp, unless you want to challenge your circuit design skills. There are more versatile op-amp models commonly available for the beginner. I recommend the LM324 for DC and low-frequency AC circuits, and the TL082 for AC projects involving audio or higher frequencies.
As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading”. I recommend resistor values between 1 kΩ and 100 kΩ.
One way you can save time and reduce the possibility of error is, to begin with a very simple circuit and incrementally add components to increase its complexity after each analysis, rather than building a whole new circuit for each practice problem. Another time-saving technique is to re-use the same components in a variety of different circuit configurations. This way, you won’t have to measure any component’s value more than once.
Reveal answerLet the electrons themselves give you the answers to your own “practice problems”!
Notes:It has been my experience that students require much practice with circuit analysis to become proficient. To this end, instructors usually provide their students with lots of practice problems to work through, and provide answers for students to check their work against. While this approach makes students proficient in circuit theory, it fails to fully educate them.
Question 2
This is a very common opamp oscillator circuit, technically of the relaxation type:
Explain how this circuit works, and what waveforms will be measured at points A and B. Be sure to make reference to RC time constants in your explanation.
Reveal answerYou will measure a sawtooth-like waveform at point A, and a square wave at point B.
Challenge question: explain how you might go about calculating the frequency of such a circuit, based on what you know about RC time constant circuits. Assume that the opamp can swing its output rail-to-rail, for simplicity.
Notes:This circuit is best understood by building and testing. If you use large capacitor values and/or a large-value resistor in the capacitor’s current path, the oscillation will be slow enough to analyze with a voltmeter rather than an oscilloscope.
Question 3
Assume that the comparator in this circuit is only capable of “swinging” its output to within 1 volt of its power supply rail voltages. Calculate the upper and lower threshold voltages, given the resistor values shown:
VUT = VLT =
Reveal answerVUT = 2.093 volts
VLT = -2.093 volts
Notes:As many opamps and comparators are incapable of rail-to-rail output swings, this question is quite realistic.
Question 4
One analogy used to explain and contrast negative feedback versus positive feedback is that of a round stone, placed on either a hilltop or a valley:
The stability of the stone in each of these scenarios represents the stability of a specific type of electrical feedback system. Which of these scenarios represents negative feedback, which represents positive feedback, and why?
Reveal answerThe valley represents negative feedback, while the hill represents positive feedback.
Notes:I have found this simple analogy to be most helpful when explaining feedback systems to students, because the behavior of each is intuitively obvious.
Question 5
A student intends to connect a TL082 opamp as a voltage follower, to “follow” the voltage generated by a potentiometer, but makes a mistake in the breadboard wiring:
Draw a schematic diagram of this faulty circuit, and determine what the voltmeter’s indication will be, explaining why it is such.
Reveal answerCircuit schematic, as wired:
The output voltage will saturate at approximately 11 volts, or -11 volts, with the potentiometer having little or no effect.
Notes:Ask your students to characterize the type of feedback exhibited in this circuit. How does this type of feedback affect the opamp’s behavior? Is it possible for the opamp to function as a voltage follower, connected like this?
Question 6
Determine the “trip” voltage of this comparator circuit: the value of input voltage at which the opamp’s output changes state from fully positive to fully negative or visa-versa:
Now, what do you suppose would happen if the output were fed back to the noninverting input through a resistor? You answer merely has to be qualitative, not quantitative:
For your information, this circuit configuration is often referred to as a Schmitt trigger.
Reveal answerWith no feedback resistor, the “trip” voltage would be 9.21 volts. With the feedback resistor in place, the “trip” voltage would change depending on the state of the opamp’s output!
Follow-up question: describe what effect this changing “trip” voltage value will have on the operation of this comparator circuit.
Notes:Schmitt trigger circuits are very popular for their ability to “cleanly” change states given a noisy input signal. I have intentionally avoided numerical calculations in this question, so that students may concentrate on the concept of positive feedback and how it affects this circuit.
Question 7
A comparator is used as a high wind speed alarm in this circuit, triggering an audio tone to sound whenever the wind speed exceeds a pre-set alarm point:
The circuit works well to warn of high wind speed, but when the wind speed is just near the threshold level, every little gust causes the alarm to briefly sound, then turn off again. What would be better is for the alarm to sound at a set wind speed, then stay on until the wind speed falls below a substantially lower threshold value (example: alarm at 60 km/h, reset at 50 km/h).
An experienced electronics technician decides to add this functionality to the circuit by adding two resistors:
Explain why this circuit alteration works to solve the problem.
Reveal answerThe added resistors provide positive feedback to the opamp circuit, causing it to exhibit hysteresis.
Challenge question: suppose you wished to increase the gap between the upper and lower alarm thresholds. What resistor value(s) would you have to alter to accomplish this adjustment?
Notes:A practical illustration for positive feedback in an opamp circuit. There is much to discuss here, even beyond the immediate context of positive feedback. Take for instance the oscillator circuit and on/off control transistor. For review, ask your students to explain how both these circuit sections function.
Question 8
Assume that the comparator in this circuit is capable of “swinging” its output fully from rail to rail. Calculate the upper and lower threshold voltages, given the resistor values shown:
VUT = VLT =
Reveal answerVUT = 8 volts
VLT = -8 volts
Challenge question: how would you recommend we change the circuit to give threshold voltages of 6 volts and -6 volts, respectively?
Notes:Ask your students to explain what the terms “upper threshold” and “lower threshold” mean with regard to input voltage in a circuit such as this.
Question 9
VUT = VLT =
Reveal answerVUT = 4.087 volts
VLT = -4.087 volts
Question 10
VUT = VLT =
Reveal answerVUT = 10.29 volts
VLT = -10.29 volts
Challenge question: how would you recommend we change the circuit so that its threshold voltages are centered around some voltage value other than zero?
Question 11
Comparators with positive feedback are sometimes referred to as Schmitt triggers. Suppose you needed a Schmitt trigger for a circuit you were building, but did not have any more integrated circuit comparators or op-amps to use. All you have available to you are discrete components. Is there any way you can think of to modify the following discrete transistor differential pair so that it behaves as a Schmitt trigger?
Reveal answer
Notes:Ask your students to determine whether this Schmitt trigger circuit is inverting or non-inverting. Have them explain their reasoning step-by-step.
Authors Paul Horowitz and Winfield Hill, in their book
The Art of Electronics, say that Q1‘s collector resistor must be larger than Q2‘s collector resistor in order for this circuit to work properly (page 232, second edition).
Question 12
Positive or regenerative feedback is an essential characteristic of all oscillator circuits. Why, then, do comparator circuits utilizing positive feedback not oscillate? Instead of oscillating, the output of a comparator circuit with positive feedback simply saturates to one of its two rail voltage values. Explain this.
Reveal answerThe positive feedback used in oscillator circuits is always phase-shifted 360o, while the positive feedback used in comparator circuits has no phase shift at all, being direct-coupled.
Notes:This is a challenging question, and may not be suitable for all students. Basically, what I’m trying to get students to do here is think carefully about the nature of positive feedback as used in comparator circuits, versus as it’s used in oscillator circuits. Students who have simply memorized the concept of “positive feedback causing oscillation” will fail to understand what is being asked in this question, much less understand the given answer.
