Don’t just sit there! Build something!! |
Avoid using the model 741 op-amp, unless you want to challenge your circuit design skills. There are more versatile op-amp models commonly available for the beginner. I recommend the LM324 for DC and low-frequency AC circuits, and the TL082 for AC projects involving audio or higher frequencies.
As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading”. I recommend resistor values between 1 kΩ and 100 kΩ.
Let the electrons themselves give you the answers to your own “practice problems”!
A common type of graph used to describe the operation of an electronic component or sub-circuit is the transfer characteristic, showing the relationship between input signal and output signal. For example, the transfer characteristic for a simple resistive voltage divider circuit is a straight line:
Once a transfer characteristic has been plotted, it may be used to predict the output signal of a circuit given any particular input signal. In this case, the transfer characteristic plot for the 2:1 voltage divider circuit tells us that the circuit will output 3 volts for an input of 6 volts:
We may use the same transfer characteristic to plot the output of the voltage divider given an AC waveform input:
While this example (a voltage divider with a 2:1 ratio) is rather trivial, it shows how transfer characteristics may be used to predict the output signal of a network given a certain input signal condition. Where transfer characteristic graphs are more practical is in predicting the behavior of nonlinear circuits. For example, the transfer characteristic for an ideal half-wave rectifier circuit looks like this:
Sketch the transfer characteristic for a realistic diode (silicon, with 0.7 volts forward drop), and use this characteristic to plot the half-wave rectified output waveform given a sinusoidal input:
Transfer characteristic graphs provide an elegant method to sketch the output waveshape for any electrical network, linear or nonlinear. The method in which points along an input waveform are reflected and transferred to equivalent points on the output waveform justifies the name of this analytical tool. Make sure your students get the opportunity to learn how to use this tool, as it can provide great insight into distortion in electronic and electromagnetic devices.
Determine the output voltage of this circuit, assuming a silicon diode (0.7 volts typical forward drop):
Now, determine the output voltage of the same circuit with a Schottky diode (0.4 volts typical forward drop) instead of a silicon PN junction diode:
Now, determine the output voltage of the same circuit with a light-emitting diode (1.7 volts typical forward drop):
Comment on these three circuits’ output voltages: what does this indicate about the effect of the diode’s voltage drop on the opamp output?
In both circuits, the output voltage is precisely -2 volts.
Follow-up question: what is different within these three circuits, if not the output voltage?
By itself, these circuits are fairly useless. Their purpose is to prepare students to understand how precision rectifier circuits work, by showing how negative feedback makes the diode’s forward voltage drop irrelevant. This is another example of the power of negative feedback, and an essential concept for understanding all precise (opamp-driven) diode circuits.
Determine the output voltage of this circuit for two different input voltage values: 5 volts, and -5 volts, assuming the use of ordinary silicon rectifying diodes:
Based on this data (and any other input conditions you wish to test this circuit under), describe what the function of this circuit is.
When Vin = 5 volts, Vout = -5 volts
When Vin = -5 volts, Vout = 0 volts
This circuit is a precision rectifier.
Work with your students to analyze the behavior of this circuit, using Ohm’s Law and the basic principle of negative feedback (zero differential input voltage). Ask your students whether or not it matters what types of diodes are used (silicon versus germanium versus light-emitting).
This opamp circuit is called a precision rectifier. Analyze its output voltage as the input voltage smoothly increases from -5 volts to 5 volts, and explain why the circuit is worthy of its name:
Assume that both diodes in this circuit are silicon switching diodes, with a nominal forward voltage drop of 0.7 volts.
Any positive input voltage, no matter how small, is “reflected” on the output as a negative voltage of equal (absolute) magnitude. The output of this circuit remains exactly at 0 volts for any negative input voltage.
Follow-up question: would it affect the output voltage if the forward voltage drop of either diode increased? Explain why or why not.
Precision rectifier circuits tend to be more difficult for students to comprehend than non-rectifying inverting or non-inverting amplifier circuits. Spend time analyzing this circuit together in class with your students, asking them to determine the magnitudes of all voltages in the circuit (and directions of current) for given input voltage conditions.
Understanding whether or not changes in diode forward voltage drop affect a precision rectifier circuit’s function is fundamental. If students comprehend nothing else about this circuit, it is the relationship between diode voltage drop and input/output transfer characteristics.
Explain why the following opamp circuit cannot be used as a rectifier in an AC-DC power supply circuit:
Here’s a hint: where does the opamp get its power from?
Believe it or not, I actually sat in an electronics class one time and listened to an instructor present the precision rectifier opamp circuit as a “precision rectifier for a power supply”. He was serious, too, claiming that this type of circuitry was used to provide split ( V/-V) voltage outputs for bench top power supplies. The saddest part of this ordeal is that none of his students recognized anything wrong with his statement (or at least did not feel comfortable in raising a question about it).
Predict how the operation of this precision rectifier circuit will be affected as a result of the following faults. Consider each fault independently (i.e. one at a time, no multiple faults):
For each of these conditions, explain why the resulting effects will occur.
The purpose of this question is to approach the domain of circuit troubleshooting from a perspective of knowing what the fault is, rather than only knowing what the symptoms are. Although this is not necessarily a realistic perspective, it helps students build the foundational knowledge necessary to diagnose a faulted circuit from empirical data. Questions such as this should be followed (eventually) by other questions asking students to identify likely faults based on measurements.
The following circuit is sometimes referred to as a polarity separator. Invent some test conditions you would use to “prove” the operation of the circuit, then analyze the circuit under those imagined conditions and see what the results are:
Explain what each output does in this “polarity separator” circuit for any given input voltage.
The Vout1 output is the inverse (negative) of any positive input voltage, while the Vout2 output is the inverse (positive) of any negative input voltage.
This circuit is a good introduction to the full-wave precision rectifier circuit, although its operation there is a bit more difficult to understand than it is here.
Determine the output voltage of this circuit for two different input voltage values: 4 volts, and -4 volts. Determine the voltage at each and every node with respect to ground as part of your analysis:
This circuit is a precision full-wave rectifier.
It is much easier to analyze the behavior of this circuit with a positive input voltage than it is to analyze it with a negative input voltage! There is a tendency for students to reach this conclusion when analyzing the circuit’s behavior with a negative input voltage:
The error seems reasonable until an analysis of current is made. If these voltages were true, Kirchhoff’s Current Law would be violated at the first opamp’s virtual ground:
Explain how you could reverse the output polarity of this precision rectifier circuit:
The answer to this question may seem too obvious to both asking. In reality, it’s just another excuse to analyze the full-wave rectifier circuit, complete with all currents and voltage drops!
One problem with PMMC (permanent magnet moving coil) meter movements is trying to get them to register AC instead of DC. Since these meter movements are polarity-sensitive, their needles merely vibrate back and forth in a useless fashion when powered by alternating current:
The same problem haunts other measurement devices and circuits designed to work with DC, including most modern analog-to-digital conversion circuits used in digital meters. Somehow, we must be able to rectify the measured AC quantity into DC for these measurement circuits to properly function.
A seemingly obvious solution is to use a bridge rectifier made of four diodes to perform the rectification:
The problem here is the forward voltage drop of the rectifying diodes. If we are measuring large voltages, this voltage loss may be negligible. However, if we are measuring small AC voltages, the drop may be unacceptable.
Explain how a precision full-wave rectifier circuit built with an opamp may adequately address this situation.
A precision opamp circuit is able to rectify the AC voltage with no voltage loss whatsoever, allowing the DC meter movement (or analog-to-digital conversion circuit) to function as designed.
The purpose of this question is to provide a practical context for precision rectifier circuits, where students can envision a real application.
Suppose that diode D1 in this precision rectifier circuit fails open. What effect will this have on the output voltage?
Hint: if it helps, draw a table of figures relating Vin with Vout, and base your answer on the tabulated results.
Instead of the output voltage remaining at exactly 0 volts for any positive input voltage, the output will be equal to the (positive) input voltage, assuming it remains unloaded as shown.
Challenge question: what mathematical function does this circuit perform, with diode D1 failed open?
Note that the given failure does not render the circuit useless, but transforms its function into something different! This is an important lesson for students to understand: that component failures may not always results in complete circuit non-function. The circuit may continue to function, just differently. And, in some cases such as this, the new function may even appear to be intentional!
Determine the output voltage of this circuit for the following input voltage conditions:
Hint: if you find this circuit too complex to analyze all at once, think of a way to simplify it so that you may analyze it one “piece” at a time.
The output voltage will be 2.2 volts, precisely.
Follow-up question: what function does this circuit perform? Can you think of any practical applications for it?
Another facet of this question to ponder with your students is the simplification process, especially for those students who experience difficulty analyzing the whole circuit. What simplification methods did your students think of when they approached this problem? What conclusions may be drawn about the general concept of problem simplification (as a problem-solving technique)?
This circuit is referred to as a peak follower-and-hold, taking the last greatest positive input voltage and “holding” that value at the output until a greater positive input voltage comes along:
Give a brief explanation of how this circuit works, as well as the purpose and function of the “reset” switch. Also, explain why a FET input opamp is required for the last stage of amplification.
I’ll let you figure out how the circuit works! With regard to the necessity of FET inputs, let me say this: if the bias current of the last opamp were too great, the circuit would “lose its memory” of the last positive peak value over time.
Follow-up question: how would you suggest choosing the values of resistor R and capacitor C?
Challenge question: redraw the circuit, replacing the mechanical reset switch with a JFET for electronic reset capability.
Ask your students if they can think of any practical applications for this type of circuit. There are many!
I find it interesting that in two very respectable texts on opamp circuitry, I have found the following peak follower-and-hold circuit given as a practical example:
This circuit contains two mistakes: the first is by having the reset switch go to ground, rather than -V. This makes the reset function set the default output to 0 volts, which makes it impossible for the circuit to subsequently follow and hold any input signal below ground potential. The second mistake is not having a resistor before the reset switch. Without a resistor in place, closing the reset switch places a momentary short-circuit on the output of the first opamp. Granted, the presence of a resistor creates a passive integrator stage (RC time constant) which must be kept considerably fast in order that rapid changes in input will be followed and held, but this is not a difficult factor to engineer.
by Jake Hertz
by Jake Hertz
