Bourns Precision Pressure Sensors | Tech Specs
Bourns BPS110 and BPS120 pressure sensors offer extreme sensitivity and stability at extremely low pressures and are designed for medical devices, industrial applications, and consumer applications.
New Product February 20, 2019 by TTI, Inc
The Bourns BPS110 and BPS120 Precision pressure sensors offer extreme sensitivity and stability at extremely low pressures and are designed for medical devices, industrial applications, and consumer appliances that require accurate measurements at low pressure, with measurement ranges from 0.15 to 1.0 PSI. The sensors, available with an analog or digital output, are fully calibrated and compensated and offer 0.25% accuracy, a 1.5% total error band, and 0.5% lifetime drift. So you know your measurements are accurate on day one and throughout the life of the device. These sensors also provide differential and gauge options and are compatible with non-corrosive dry gases.
  • Pressure ranges: 0.15 PSI, 0.30 PSI, 1.0 PSI
  • Output: amplified analog or I2C (13-bit)
  • Fully calibrated and active temperature compensation
  • Total Error Band: 1.5% FS (0°C to +60°C)
  • Lifetime drift: 0.5% FS
  • Differential and gauge options
More Information
