Maxim Integrated MAX77324 Evaluation Kit | New Product Brief
Maxim Integrated’s MAX77324 Evaluation Kit supports the evaluation and design of high-efficiency step-down converters using the ultra-small MAX77324 buck converter.
New Product September 17, 2018 by Mouser
Maxim Integrated’s MAX77324 Evaluation Kit supports the evaluation and design of high-efficiency step-down converters using the ultra-small MAX77324 buck converter. The MAX77324 can output up to 1.5A at 0.6V to 2V with ±2% voltage accuracy, and operates from a 2.5V to 4.8V supply with up to 93% conversion efficiency. The converter is packaged in a small 6-bump WLP and switches at 2MHz, allowing the use of a 0603 inductor and resulting in a total solution size of just 6.89mm2. The MAX77324 uses a constant-on-time PWM control scheme with an automatic SKIP mode for high light-load efficiency.
The evaluation kit provides a proven design with connection points for easy evaluation and high accuracy measurements, as well as a test point and jumper for the IC’s enable pin.
  • Evaluation kit for MAX77324 1.5A output current step-down converter
  • 0.6V to 2V adjustable VOUT range, ±2% accuracy
  • 93% peak efficiency
  • 2MHz nominal switching frequency enables use of 0603 inductor
  • 1.22x0.85mm, 6-bump WLP, 6.89mm2 total solution area
  • Proven PCB reference design and layout
More Information
