Vishay VJ HIFREQ HT Series Capacitor | Tech Specs
New Product December 04, 2020 by TTI, Inc
Vishay’s VJ HIFREQ HT series capacitors are designed for high frequency and high temperature operation, but where other so-called high temp capacitors might be qualified to 150 degrees C, the VJ HIFREQ HT series is qualified to 200 degrees C.
The capacitors have an ultra-stable dielectric that provides a minimum temperature coefficient of capacitance and 0% aging. They’re ideal for base stations, military communications, and more, with a high Q, low ESR, and high resonant frequencies.
The capacitors are offered in case sizes from 0402 to 1111, with capacitance values from 0.1 to 2200 picofarads and voltage ratings up to 500 volts DC.
  • Operating Temperature: -55°C to +200°C
  • Temperature Coefficient of Capacitance: 0 ppm/°C ± 30 ppm/°C (-55°C to +200°C)
  • Aging Rate: 0% maximum per decade
  • High Q, low ESR, high SRF/PRF
  • Capacitance Values: 0.1pF to 2200pF
  • Voltage Rating: 25VDC to 500VDC
Click here for more information.
