Infineon Adds Quad-Motor Control & Post-Quantum Secure Boot to PSOC MCUs
The PSC3M6 and PSC3P6 extend the Main Line with on-chip op-amps, USB, I3C, and LMS-based firmware verification aligned with CNSA 2.0.
News November 12, 2026 by Luke James
Infineon Technologies has expanded its PSOC Control C3 microcontroller family with the PSC3M6 and PSC3P6, a pair of Arm Cortex-M33 devices built for systems that run several motors or multiple power-conversion stages from a single chip. The 180-MHz parts control up to four brushless DC motors, integrate operational amplifiers alongside the family’s existing high-speed analog block, and verify their own firmware with post-quantum cryptography.
The new PSOC Control C3 microcontroller family.
The new devices slot into the Main Line of the PSOC Control C3 family, which Infineon introduced in January 2025 with Entry, Main, and Performance tiers aimed at motor drives, power factor correction, and wide-bandgap power conversion. The PSC3M6 is the motor-control variant, and the PSC3P6 targets power conversion, with packages of up to 100 pins.
Four Motors From One Controller
The headline capability is sensored or sensorless field-oriented control of up to four BLDC motors on one MCU. Infineon positions this for quad-motor systems, PFC stages, and very high-RPM drives that need deterministic, real-time loop closure. Steve Tateosian, senior vice president and general manager of IoT, consumer, and industrial MCUs at Infineon, said the parts are designed for multi-motor and power-conversion systems that need high performance without growing the board footprint.
Diagram of the PSOC Control C3M/P5
Simplified diagram of the PSOC Control C3M/P5.
The compute side is the same 180-MHz Cortex-M33 used across the Main Line, with a floating-point unit, DSP extensions, and a CORDIC coprocessor that offloads the trigonometric and hyperbolic math used in Clarke and Park transforms. The Main Line datasheet lists 256 KB of read-while-write flash with ECC, 64 KB of ECC SRAM, two 16-channel DMA controllers, up to two CAN FD channels, and six serial communication blocks. The M6/P6 add full-speed USB and an I3C interface to that list, and Infineon describes the family as pin-compatible across memory, package, and feature options so that designs can scale up or down without a relayout.
Applications named in the announcement span industrial drives, robotics, drones, home appliances, renewables, power supplies, telecom servers, data centers, and digital healthcare.
Post-Quantum Firmware Verification
The security block is what separates the M6/P6 from the PSC3M5/P5 they build on. Secure boot and firmware-update verification use SHA-512 hashing with Leighton-Micali Signatures (LMS), a stateful hash-based signature scheme standardized in NIST SP 800-208. Hash-based schemes derive their security from the hash function rather than from integer factorization or elliptic-curve discrete logarithms, so Shor’s algorithm running on a large quantum computer doesn’t break them.
Infineon says the implementation complies with the firmware-protection requirements of the NSA’s Commercial National Security Algorithm Suite 2.0 (CNSA 2.0), which calls for quantum-resistant software and firmware signing to be used exclusively by 2030. The company also cites the EU Cyber Resilience Act, which imposes secure-update obligations on products with digital elements. The parts support PSA Certified Level 3 and are DICE-ready, meaning they can generate hardware-rooted device identities for attestation. The earlier PSC3M5/P5 were certified to PSA Level 2.
Functional block diagram of the PSOC Control C3M/P5
Functional block diagram of the PSOC Control C3M/P5. (See page 6 of datasheet for enlarged image.)
One practical consequence of LMS is worth noting for firmware teams: because the scheme is stateful, each one-time signing key can be used exactly once, and a build server that reuses key state compromises the signature. Teams moving from ECDSA signing workflows will need to manage signer state accordingly.
Analog Integration and Tooling
Much of the component savings come from the analog front end. The Main Line’s High-Performance Programmable Analog Subsystem (HPPASS) includes a 12-bit SAR ADC sampling at up to 12 Msps across 16 channels, with per-channel gains of 1, 3, 6, and 12 and hardware oversampling. Five comparators with built-in 10-bit DACs and slope generators respond in under 10 nanoseconds, which is fast enough to implement cycle-by-cycle overcurrent trips in hardware. Four 32-bit timer channels provide high-resolution PWM with a step size better than 80 ps, a requirement for the switching frequencies that GaN and SiC stages run at.
The M6/P6 add on-chip operational amplifiers to that block, which lets designers condition shunt-based phase-current signals on the MCU rather than with external amplifiers. Combined with the integrated comparators and DAC, this creates a current-sensing and protection chain that would otherwise require several discrete analog parts per motor phase.
On the software side, ModusToolbox supports the parts with the Motor Suite and Power Suite graphical environments, which bundle control libraries and tuning tools. A ModusToolbox AI Assistant is intended to help migrate existing designs from other MCU platforms.
All images used courtesy of Infineon.
