Microchip Ramps Security on Touchscreen Controllers for EV Chargers
As the number of EVs on the road increases, Microchip has expanded its maXTouch touchscreen controller family to support the growing demand for touchscreen-based charging stations.
Last week, Microchip announced that it is expanding the maXTouch family of touchscreen controllers with enhanced security for electronic payment systems and built-in mitigation against weather and outdoor threats.
ATMXT2952TD The maXTouch 2.0 controllers offer enhanced security capabilities. Image used courtesy of Microchip
Microchip says that the new MXT2952TD 2.0 devices offer “exceptional” noise immunity and can be used with IK10-standard touchscreens featuring anti-glare and other types of protective coatings.
Touchscreen Controllers Resilient to Outdoor Conditions
Touchscreens and their controllers used in outdoor EV charging stations must withstand adverse weather conditions and offer a reliable way to transfer customer data to the operational backend. For instance, moisture may condense on a touchscreen surface and cause inaccurate readings that are sent to the touchscreen controller.
Additionally, “false touches” can happen if significant water droplets or moisture condense on a touchscreen surface. Microchip's new touchscreen controllers, the ATMXT2952TD-C2UEN, can compensate for these effects and eliminate the possibility of false touches, even with up to 22 mm of water condensation.
Condensation on touchscreens can adversely affect performance. Image used courtesy of Microchip
The device also features various other noise-suppression features to compensate for situations arising from multi-touch interactions. These include a lens-bend algorithm to adjust for warping in the touchscreen display, touch suppression to mitigate effects from unwanted screen touches, and self-capacitance sensing to respond to both bare finger touches and glove usage.
The product brief mentions that the device can support up to a 21-inch touchscreen display and has automatic touch sensor diagnostics, which can be reported using a dedicated output pin.
Another concern with outdoor touchscreens besides the weather is vandalism. Consequently, the ATMXT2952TD 2.0 can be used with IK10-standard, 6-mm glass displays. An IK10 display meets standard IEC 62262 level ten, which indicates the highest level of protection against external mechanical impacts.
K Code |
IK00 |
IK01 |
IK02 |
IK03 |
IK04 |
IK05 |
IK06 |
IK07 |
IK08 |
IK09 |
IK10 |
| Impact Energy (Jules) | –– |
0,14 |
0,2 |
0,35 |
0,5 |
0,7 |
1 | 2 | 5 | 10 | 20 |
| Weight (g) | –– | 200 | 200 | 200 | 200 | 200 | 500 | 500 | 1700 | 5000 | 5000 |
| Impact Height (cm) | –– |
7.5 |
10 |
17.5 |
25 | 35 | 20 | 40 |
29.5 |
20 | 40 |
The 2.0 Family Enhances Security Features
The new MXT2952TD 2.0 touchscreen controllers mitigate the threat of malicious actors gaining access to sensitive customer information by encrypting touch information and cryptographically authenticating software updates. The new 2.0 family allows customers to integrate secure credit card payment services into a touchscreen-based EV charging station.
The 2.0 family allows customers to run firmware directly on the controller, eliminating the chance of man-in-the-middle attacks that can occur when, for example, an RFID reader and touchscreen controller are on different physical PCBs.
Man-in-the-middle attacks are a particular vulnerability of complex electronic systems. Image used courtesy of Invicti
A man-in-the-middle attack allows a malicious actor to access personal information by intercepting communication between two elements. Using the 2.0 family, however, firmware can run directly on the controller, eliminating the need for separate RFID and controller boards. In one scenario, the user may simply enter a secure PIN on the touchscreen and authenticate directly for payment.
