Microchip’s 100/1000BASE‑T1 SPE PHYs Pack Security and Safety Features
The new 100/1000BASE-T1 transceiver families integrate IEEE 802.1AE-2018 frame security and TSN, targeting ADAS, zonal architectures, and industrial automation.
News May 20, 2026 by Luke James
Microchip Technology has introduced the LAN878x and LAN888x families of single-pair Ethernet (SPE) PHY transceivers, integrating hardware-based MACsec security, native time-sensitive networking, and ISO 26262 ASIL-B functional safety across 100BASE-T1, 1000BASE-T1, and dual-speed variants.
Single Pair Ethernet (SPE) PHY transceivers
The new LAN878x and LAN888x chips.
The launch targets software-defined vehicles, zonal automotive architectures, and industrial determinism networks where security and timing requirements have outgrown previous-generation SPE PHYs.
MACsec, TSN, and Functional Safety On-Chip
The LAN878x and LAN888x devices implement IEEE 802.1AE-2018 MACsec in hardware, providing frame-level confidentiality, data integrity, and replay protection without adding software stack overhead or latency. Pushing MACsec into the PHY rather than the MAC or the host CPU removes a class of side-channel and software-vulnerability exposures that have grown in importance as automakers expand exposure to over-the-air update channels and aftermarket diagnostic interfaces.
Native TSN support handles deterministic, low-latency communication required for ADAS, zonal gateways, and safety-critical control loops, although Microchip didn’t list which TSN sub-standards (such as 802.1AS-2020, 802.1Qbv, or 802.1Qci) are implemented in the launch materials. The functional-safety engineering targets ISO 26262 ASIL-B systems, with on-chip diagnostics and link monitoring intended to accelerate fault detection and feed system-level safety mechanisms, in what Microchip describes as "stronger system-level safety mechanisms than traditional SPE PHY solutions."
All devices are designed for Automotive Grade 1 operation, with a maximum junction temperature of 150°C and an operating range of -40°C to 125°C, allowing them to sit in engine compartments and other harsh thermal environments alongside zone controllers.
Pin-Compatible Scaling Across Speeds
The LAN878x family includes the LAN8781, LAN8781M, LAN8782, and LAN8782M, while the LAN888x family includes the LAN8881, LAN8881M, LAN8882, LAN8882M, LAN8883, LAN8883M, LAN8884, and LAN8884M. The "M" suffix denotes MACsec support; non-M variants omit the security block while retaining TSN and ASIL-B features. Both families offer pin-compatible SKUs for 100BASE-T1 and 1000BASE-T1 variants, as well as for SGMII and RGMII host interfaces.
Pin compatibility enables vehicle and industrial OEMs to reuse a single PCB design across multiple network bandwidth and security tiers, reducing engineering costs when scaling from a low-cost zonal sensor link to a 1000BASE-T1 backbone link without redesigning the host board. The same approach lets buyers stage MACsec adoption: ship a non-M variant in early production, then drop in an M variant on the same footprint when MACsec becomes a contractual requirement.
SPE Buildout
Single-pair Ethernet adoption has accelerated as OEMs replace legacy CAN, FlexRay, and LIN segments with all-Ethernet zonal architectures that simplify wiring harnesses and consolidate compute into fewer high-power zone controllers.
The 100BASE-T1 and 1000BASE-T1 variants of SPE, defined by IEEE 802.3bw and 802.3bp, respectively, support up to 15 m of single twisted-pair cable at gigabit rates and longer runs at 100 Mbps, making them well-suited to in-vehicle, robotics, and process-automation deployments where weight and space drive routing decisions.
Overview of SPE standards
Overview of SPE standards.
Microchip is competing against Marvell's 88Q2220 and 88Q5050 SPE PHYs, Texas Instruments' DP83TG720 and DP83TC81x families, and Realtek's RTL9011AA, all of which target similar automotive and industrial customers. The integration of MACsec at the PHY layer remains a differentiator, with most competing parts implementing security at the MAC or expecting host-side handling.
Industrial adoption of SPE has lagged in the automotive segment, but is accelerating as IEC 63171-6 and IEC 63171-2 connectors stabilize, and factory floor designers replace legacy fieldbus protocols with Ethernet. UN Regulation No. 155 and ISO/SAE 21434 now require OEMs to demonstrate vehicle network security for approval in the European Union, Japan, and South Korea. Hardware-level MACsec helps satisfy those requirements without forcing software teams to implement frame-level cryptography.
The LAN878x and LAN888x devices are sampling now to lead customers, with hardware evaluation platforms, SGMII, USB, and PCIe plug-in boards, and Linux software drivers available as supporting development tools.
All images used courtesy of Microchip.
