Teardown Tuesday: Digital Kitchen Scale with LCD
In this Teardown Tuesday, we are going to take a look at the inner workings of a small scale that is designed to track calories.
The nutrition scale. Image courtesy of Amazon
This scale features an LCD display that shows various nutritional information and a keypad that lets the user type in new foods and recall food that is already programmed in. The scale came with documentation for the 100s of food codes that were pre-programmed.
Opening It Up
This was easy to open. Removal of four small and two large Phillips head screws allowed the halves of the housing to separate and the load cell assembly to pull apart. The circuit boards and display were removed with a few more small phillips screws
Circuit Boards
The top side of the main PCB
Inside of this scale, there are two circuit boards. The primary circuit board is a two-layer board with through-hole and surface mount components on a single side. There is green soldermask on both sides and white silkscreen on the component side. A few of the through-hole components are simply soldered onto surface-mount pads.
The bottom side of the main PCB
There is a second PCB in this scale with two push buttons. This is a single-sided PCB without silkscreen and with green soldermask on one side. The two buttons are wired in parallel. There are two wires attached to the board that are stress-relieved with hot-melt glue.
In addition to the two tactile buttons on the secondary PCB, there are 14 membrane dome switches to allow the user enter information about the food that is being placed on the scale. The membrane switch assembly connects to the main PCB with a flexible ribbon cable. This cable slides into a connector and relies on friction to hold it in place.
The power buttons
Die Packages!
Located on the PCB are two ICs in die packages that are encapsulated in epoxy. Based on the trace layout, U1 controls the operation of the scale and U2 controls the interfacing to the LCD. The epoxy was sanded off of U2 to reveal the die inside.
The LCD driver in a die package
Sanding the epoxy is not the most gentle way to remove it. Many people have had success using various acids. In the sanding process, the the bond wires and die were damaged. The disconnected bond wires can be seen on four of the sides and the die can be see in the middle of the above image.
Load Cell
The load cell
A load cell is used to measure the weight of the food placed on this scale. This load cell is a bar style with four strain gauges placed on opposite sides. Two of these strain gauges are measuring tensions while the other two are measuring compression. These strain gauges vary in resistance based on the amount of flexing of the beam they are attached to. They are connected to form a wheatstone bridge.
Two of the strain gauges
Display
The LCD
To let the user see the nutritional data that they are measuring, this scale features an LCD display. This display has text that is printed onto the glass and segments to display the values.
All the segments
Connecting the LCD to the PCB is an elastomer (or zebra) connector. This connector is made from two silicone materials, one of which is impregnated with a conductor and the other is an insulator. This flexible conductor measures 2.5” wide, 0.1875” tall, and 0.079” thick.
The zebra connector
There are a total of 52 connections from the LCD to the PCB. There are exposed pads on the PCB that measure 2mm by about 0.5mm and have an ENIG finish. All of these pads connect back to the LCD driver, U2, mentioned above.
The PCB contacts for the LCD
The date code on this PCB puts the layout date at about seven years ago. The construction of this scale is very similar to the other scale teardown we have done, the Bluetooth bathroom scale. At $40USD, there are other electronics that we have done teardowns for that offer a lot more tech-per-dollar.
Thanks for taking a look at this Teardown Tuesday! Stop by next week for another teardown!
Next Teardown: Square Chip and NFC Reader
Hey, Alex. That was wonderful. I never knew about the CoB and the zebra connectors. See you next Tuesday.
