Xilinx Hardware Accelerators Link Up With O-RAN to Push 5G Server Performance
Hardware acceleration is said to create a new 5G throughput reality with 42x encoding and 24x decoding improvements for FEC and HARQ line coding.
News September 21, 2020 by Adrian Gibbons
Just this month, Xilinx unveiled the T1, a new hardware accelerator card designed to offload 5G Open Radio Access Network (O-RAN) fronthaul transport requirements and the computationally-intensive, low-density parity checks (LDPC) in the L1 network stack.
Xilinx T1 PCIe Telco accelerator card
The Xilinx T1 PCIe Telco accelerator card with onboard SFP28 cages for 25G optical communications includes DDR4 memory for HARQ lookup and calculation in a compact 75W form factor. Image used courtesy of Nickel Boards
In conjunction with partner-developed IP cores and the O-RAN Alliance, Xilinx says it is optimizing 5G server performance with the T1 PCIe accelerator card. The Xilinx T1 card is an x16 Gen 3 PCIe smart NIC based upon the Zynq Ultrascale+ FPGA and a Zynq RFSoC chipset.
Higher Data Rates Call for Hardware Acceleration
Network virtualization of 5G aggregate data in software has resulted in throughput limitations because the higher data rates defined by the 3GPP can only be overcome with hardware acceleration. Xilinx says its T1 hardware accelerator used alongside a commercial off-the-shelf server results in orders of magnitude higher throughput and reduced latency.
Layer 1 Offload Reference Design
The T1 reference design incorporates partner IP cores providing for high-performance processing of networking functions, effectively splitting the networking functions of the RAN from the commercial applications. Image used courtesy of Xilinx
The T1 offloads the two most intensive operations in a radio access network: 1) fronthaul termination between the radio unit and the distributed unit and 2) L1 forward error correction (FEC), hybrid automatic repeat request (HARQ), and other high PHY functions.
Additionally, Xilinx reports 15 to 30 times improvement in ZUC and IPSec algorithms, which are part of the packet data convergence protocol (PDCP).
Jessy Cavazos, writing for Keysight, describes the O-RAN solution as capable of increasing data rates for mobile networks as the 7-2 split.
Functional splits of 5G RAN
Functional splits of 5G RAN. Image used courtesy of Keysight Technologies
The 7-2 split breaks up the PHY into a high-PHY and low-PHY (option 7) whose functions are split between the radio unit (O-RU) and the distributed unit (O-DU). Then, the computationally intensive operations (option 2) are carried out by the centralized unit (O-CU) baseband unit where we find the Xilinx T1 accelerator.
O-RAN: Open Interfaces, Multi-Vendor Support, Better Ecosystems
In the press release for the accelerator, Xilinx's VP of marketing for the company's wired and wireless group, Dan Mansur, says, “the trend toward network virtualization and O-RAN has given us an opportunity with the Xilinx T1 Telco Accelerator Card to drive the next steps of disaggregation of standard networks, enabling our expansion into every corner of the 5G market."
He explains that the company is collaborating with its ecosystem partners to enhance Xilinx's hardware, IP, and software to lead "the innovation and realization of 5G O-RAN networks.”
The Xilinx Ultrascale+ FPGA ecosystem aligns well with the O-RAN Alliance's objective of open hardware interfaces, which is said to facilitate vendor competition and lead to improved systems and lower cost deployments. The T1 offers pre-loaded industry partner FPGA reference designs, which can interface through the PCIe interface with the industry-standard baseband device (BBDev) API on the open-source FlexRAN x86 user platform.
Intel & ASTRI are collaborating on the development of the cloud-based RAN virtualization
Intel & ASTRI are collaborating on the development of the cloud-based RAN virtualization, which takes advantage of the FlexRAN split between remote radio units (RRUs) and the centralized baseband units (BBUs). Image used courtesy of Intel
Hardware acceleration may be the key to actualizing 5G throughput and low-latency targets in radio fronthaul links. General-purpose processors on the network edge are then freed to do the more important commercial tasks of providing streaming, gaming, and automotive services.
