Understanding the Characteristics of Narrowband Noise in Communication Systems
In this article, we analyze how bandpass filtering affects the power spectral density (PSD) of noise and explore how noise can be described by in-phase and quadrature components.
Technical Article June 14, 2026 by Dr. Steve Arar
Some years ago, I authored a three-part series on the noise concepts most relevant to electronics engineers. The series covered basic topics such as the significance of the probability density function (PDF), methods for calculating noise RMS and peak-to-peak values, and an introduction to the power spectral density (PSD) function.
Analyzing the noise performance of communication systems requires that we take more advanced considerations into account. This is particularly true in the context of modulation schemes. Most communication systems include a bandpass filter, typically as an early stage in the signal path. As a result, one key area of interest is the behavior of narrowband noise.
In this article, we explore how bandpass filtering alters noise characteristics and present a useful representation using in-phase and quadrature components. This framework will set the stage for evaluating the signal-to-noise ratio (SNR) in AM and FM systems in subsequent articles.
How Does Bandpass Filtering Alter Noise Characteristics?
Consider applying white noise to a bandpass filter with center frequency fc and bandwidth 2B, as illustrated in Figure 1.
Top: White noise applied to a bandpass filter. Bottom: The corresponding filter frequency response.
Figure 1. White noise applied to a bandpass filter (a) and corresponding filter frequency response (b).
This situation represents the noise observed at the output of the intermediate-frequency (IF) stages in most communication receivers. The noise term nw(t) denotes additive white Gaussian noise with a zero mean and a double-sided power spectral density of N0/2 in W/Hz. The PSD is illustrated in Figure 2.
PSD of the input white noise.
Figure 2. PSD of the input white noise.
Passing through the bandpass filter alters the noise's statistical properties. In particular, its PSD is reshaped according to the squared magnitude of the filter's frequency response. In mathematical language, the noise PSD at the output of the bandpass filter is:
$$S_N(f)~=~|H_R(f)|^2~\times~N_0/2$$
Equation 1.
where HR(f) denotes the bandpass filter's transfer function. Assuming an ideal bandpass filter with unity gain across its passband, the resulting output noise PSD is shown in Figure 3.
Noise at the output of the bandpass filter.
Figure 3. Noise at the output of the bandpass filter.
The input noise with a two-sided PSD of N0/2 yields an output PSD of the same level, but confined to the filter's bandwidth (2B). In practice, the bandpass noise PSD is often centered around a carrier frequency (fc) much higher than 2B. We might say bandpass noise arises when white noise passes through a bandpass filter.
Typical Time-Domain Waveform
If the filter center frequency is much greater than 2B, then the output signal would resemble a sine wave at fc, whose amplitude and phase vary slowly and randomly over time. Figure 4 shows a typical waveform for the narrowband noise at the filter output.
Time-domain sample function of a narrowband noise process with a
bandwidth of 2B.
Figure 4. Time-domain sample function of a narrowband noise process with a bandwidth of 2B.
In the rest of the article, we'll learn how narrowband noise can be described through its in-phase and quadrature components. To clarify this framework, we'll first revisit how such a representation works for a bandpass signal.
In-Phase and Quadrature Noise Components
In an earlier article, "How Phasors Help Us Understand Bandpass Signals," we learned that real-valued bandpass signals in communication systems can be represented by equivalent complex-valued baseband signals. That discussion showed that all the information in a narrowband signal centered around a carrier frequency can be captured by two lowpass components: the in-phase and quadrature signals.
For deeper insight into this representation, I recommend reviewing the abovementioned article. Meanwhile, let's review the key equations from that article to lay the groundwork for our current exploration of noise.
Consider the following modulated wave centered at ωc:
$$s_{RF}(t) ~=~ A(t) \cos \big ( \omega_c t ~+~ \theta(t) \big )$$
Equation 2.
where A(t) and θ(t) are the instantaneous amplitude and phase of the signal, respectively.
Using a concept analogous to phasor representation in AC circuit analysis, the above equation can be rewritten as:
$$s_{RF}(t) ~=~ Re \Big \{ \big [A(t) e^{j \theta(t)} \big ] e^{j \omega_c t} \Big \}$$
Equation 3.
In practice, A(t) and θ(t) vary slowly relative to the carrier frequency (ωc). As a result, the above formulation separates the signal into fast and slow components. The term inside the brackets is known as the complex baseband representation of the signal:
$$s_l (t) ~=~ A(t) e^{j \theta(t)}$$
Equation 4.
This complex-valued function may be expressed in Cartesian form:
$$s_l(t) ~=~ s_i(t) ~+~ j s_q (t)$$
Equation 5.
where si(t) and sq(t) are lowpass real-valued functions. These are the in-phase and quadrature components.
From Equations 4 and 5, the in-phase and quadrature components are obtained as:
$$s_i(t) ~=~ A(t) \cos ( \theta) \quad \text{and} \quad s_q(t)~=~A(t) \sin( \theta)$$
Equation 6.
Next, by substituting the Cartesian form of sl(t) from Equation 5 into Equation 3 and applying Euler's formula to expand the ejωct term, we can express the original RF signal in terms of its in-phase and quadrature components:
$$s_i(t) ~=~ A(t) \cos ( \theta) \quad ~\text{and}~ \quad s_q(t)~=~A(t) \sin( \theta)$$
Equation 7.
This result provides valuable insight into the operation of radio communication systems. Just like bandpass signals, bandpass noise can also be represented in the canonical form as:
$$n(t) ~=~ n_{I}(t) \ \cos(\omega_c t) ~-~ n_{Q}(t) \ \sin(\omega_c t)$$
Equation 8.
where nI(t) and nQ(t) are the in-phase and quadrature components of noise. Both noise components are measured with respect to the carrier wave, Accos(ωct).
The key distinction between a bandpass signal and bandpass noise lies in the behavior of A(t) and θ(t) in Equation 2. For signals, these quantities depend on the message, whereas for noise, they vary randomly.
Important Properties of the In-Phase and Quadrature Noise Components
The lowpass noise components, nI(t) and nQ(t), capture all aspects of the narrowband noise aside from its carrier frequency. Figure 5(a) illustrates how bandpass noise can be decomposed into its in-phase and quadrature components. Figure 5(b) shows how these components can be used to reconstruct the original noise.
Left: Decomposition of bandpass noise into in-phase and quadrature components. Right: reconstruction of bandpass noise from its baseband representation.
Figure 5. Left: Decomposition of bandpass noise into in-phase and quadrature components. Right: reconstruction of bandpass noise from its baseband representation.
If the bandwidth of the noise is 2B, as shown in Figure 3, then the ideal lowpass filters in the above figure should have a bandwidth of B.
The following are key properties of the in-phase and quadrature noise components, stated without proof. We'll refer back to Figure 3 as we examine these.
First, the in-phase and quadrature noise components are zero-mean, lowpass, jointly stationary, and jointly Gaussian random processes.
Second, if the power of the bandpass noise is Pn, then the power of each of the in-phase and quadrature components is also Pn. This relationship is captured by the following equation:
$$P_n ~=~ \int_{- \infty} ^{+\infty} S_N(f) \ df ~=~ \int_{- \infty} ^{+\infty} S_I(f) \ df ~=~ \int_{- \infty} ^{+\infty} S_Q(f) \ df$$
Equation 9.
where:
SN(f) is the power spectral density of the bandpass noise
SI(f) is the power spectral density of the in-phase component
SQ(f) is the power spectral density of the quadrature component.
Third, both the in-phase and quadrature noise components have the same PSD, which is related to the PSD of the bandpass noise by the following equation:
$$S_I(f) ~=~ S_Q(f) ~=~\begin{cases} S_N(f~-~f_c) ~+~ S_N(f~+~f_c), & -B ~<~ f ~<~ B \\ 0, & otherwise \end{cases}$$
Equation 10.
where it's assumed that SN(f) occupies a frequency range of:
$$f_c~+~B~\leq~|f|~\leq~f_c~+~B$$
Equation 11.
as shown in Figure 3.
Explaining how the PSDs of the in-phase and quadrature components relate to that of narrowband noise is more straightforward in words than in equations. In short, we obtain SI(f) and SQ(f) by shifting the positive-frequency portion of SN(f) leftward by fc, and the negative-frequency portion rightward by fc, then summing the two resulting spectra. The example problems in the following sections will clarify this.
Finally, if the bandpass noise is Gaussian and its PSD is symmetric about the carrier frequency, then the in-phase and quadrature components are statistically independent.
To reinforce the concepts we just discussed, let's explore a few examples.
Example 1: I/Q PSDs When Bandpass Noise Spectrum Is Centered at Carrier
Assume the bandpass noise has a PSD of N0/2, and that the carrier frequency lies at the center of its spectrum, as illustrated in Figure 6. This scenario arises when evaluating the noise performance of conventional AM and FM systems.
PSD of bandpass noise centered at the carrier frequency.
Figure 6. PSD of bandpass noise centered at the carrier frequency.
Using Figure 6, let's determine the PSDs of the in-phase and quadrature noise components.
Solution
In Figure 7, the green spectrum represents the positive-frequency portion of SN(f) shifted downward by fc, while the blue spectrum corresponds to the negative-frequency portion shifted upward by fc.
Positive and negative frequency components of the bandpass noise PSD shifted by plus and minus fc to baseband.
Figure 7. Positive and negative frequency components of SN(f) shifted by ±fc to baseband.
When the two shifted components are combined, they yield a flat PSD of N0 spanning −B to B, as shown in Figure 8.
Combined PSD of the in-phase and quadrature noise components.
Figure 8. PSD of the in-phase and quadrature noise components.
Example 2: I/Q PSDs with Carrier Positioned at the Spectrum's Lower Edge
As in the previous example, let's assume the bandpass noise has a PSD of N0/2. However, the positive-frequency portion of the spectrum now spans from fc to fc + B, as shown in Figure 9. Determine the PSDs of the in-phase and quadrature components.
Bandpass noise spectrum positioned just above the carrier frequency.
Figure 9. Bandpass noise spectrum positioned just above the carrier frequency.
Solution
In Figure 10, the green spectrum represents the positive-frequency segment of SN​(f), which is shifted downward by fc. The blue spectrum represents the negative-frequency segment, which is shifted upward by fc.
Positive and negative frequency components of the new bandpass noise PSD, shifted by plus and minus fc to baseband.
Figure 10. Positive and negative frequency components of the new SN(f) shifted by ±fc to baseband.
By combining the two frequency-shifted components, we obtain the orange spectrum illustrated in Figure 11.
PSD of the in-phase and quadrature noise components for the second example.
Figure 11. PSD of the in-phase and quadrature noise components for the second example.
Unlike the previous case, which produced a flat PSD of N0 over [−B, B], the arrangement in this example yields a flat PSD of N0/2 across [−B, B]. This latter scenario is typical of suppressed-sideband modulation schemes.
Example 3: Statistical Independence of the In-Phase and Quadrature Components
Assume that the carrier frequency lies at the center of the bandpass noise spectrum, as illustrated in Figure 6. Determine the PSD of the following random process:
$$X(t)~=~a~\times~n_I(t)~+~b~\times~n_Q(t)$$
Equation 12.
where a and b are constant values.
Solution
Since the bandpass noise PSD is symmetric about the carrier frequency, the in-phase and quadrature components are statistically independent. Therefore, we're dealing with the sum of two independent, zero-mean processes.
Because nI(t) and nQ(t) are statistically independent, their cross-power spectral density is zero, and the PSD of X(t) is simply the sum of the individual PSDs scaled by the square of the corresponding multiplicative factors. Hence, the total PSD is:
$$S_X(f) ~=~ a^2 ~\times~ S_I(f) ~+~ b^2 ~\times~ S_Q(f)$$
Equation 13.
Wrapping Up
In this article, we examined the characteristics of bandpass noise, emphasizing its decomposition into in-phase and quadrature components. With this framework in place, we're now equipped to examine how SNR behaves in AM and FM systems, which will be the focus of the following articles in this series.
All images used courtesy of Steve Arar
