AC Electric Circuits
Advanced Electromagnetism and Electromagnetic Induction
11 questions By Tony R. Kuphaldt
Page 1 of 4 0 of 11 answers revealed (0%)
  • Question 1 of 11
    ∫f(x) dx Calculus alert!
    Electronic power conversion circuits known as inverters convert DC into AC by using transistor switching elements to periodically reverse the polarity of the DC voltage. Usually, inverters also increase the voltage level of the input power by applying the switched-DC voltage to the primary winding of a step-up transformer. You may think of an inverter’s switching electronics as akin to double-pole, double-throw switch being flipped back and forth many times per second:
    The first commercially available inverters produced simple square-wave output:
    However, this caused problems for most power transformers designed to operate on sine-wave AC power. When powered by the square-wave output of such an inverter, most transformers would saturate due to excessive magnetic flux accumulating in the core at certain points of the waveform’s cycle. To describe this in the simplest terms, a square wave possesses a greater volt-second product than a sine wave with the same peak amplitude and fundamental frequency.
    This problem could be avoided by decreasing the peak voltage of the square wave, but then some types of powered equipment would experience difficulty due to insufficient (maximum) voltage:
    A workable solution to this dilemma turned out to be a modified duty cycle for the square wave:
    Calculate the fraction of the half-cycle for which this modified square wave is “on,” in order to have the same volt-second product as a sine wave for one-half cycle (from 0 to π radians):
    Hint: it is a matter of calculating the respective areas underneath each waveform in the half-cycle domain.
    Reveal answer
  • Question 2 of 11
    An electric arc welder is a power conversion device, used to step utility power voltage (usually 240 or 480 volts AC) down to a low voltage, and conversely step up the current (to 100 amps or more), to generate a very hot arc used to weld metal pieces together:
    The simplest designs of arc welder are nothing more than a large step-down transformer. To achieve different power intensities for welding different thicknesses of metal, some of these arc welders are equipped with taps on the secondary winding:
    Some arc welder designs achieve continuous variability by moving a magnetic ßhunt” in and out of the transformer core structure:
    Explain how this shunt works. Which way does it need to be moved in order to increase the intensity of the welding arc? What advantages does this method of arc power control have over a “tapped” secondary winding?
    Reveal answer
  • Question 3 of 11
    The majority of the “humming” sound emitted by an unloaded transformer is due to an effect known as magnetostriction. What is this effect, exactly?
    Reveal answer
Related Tools:
  • Hilineload April 16, 2025
    Question 5 - If the source voltage polarity is reversed, would the decay of the field respond quicker than if the source voltage was simply turned off?  In other words, would the slope of the flux decay/growth be steeper at voltage reversal, than what it is at its initial condition when the voltage is first applied?
