Discrete Semiconductor Devices and Circuits
Clipper and Clamper Circuits
21 questions By Tony R. Kuphaldt
Question 1 of 21
Don’t just sit there! Build something!! Learning to mathematically analyze circuits requires much study and practice. Typically, students practice by working through lots of sample problems and checking their answers against those provided by the textbook or the instructor. While this is good, there is a much better way.
- Carefully measure and record all component values prior to circuit construction, choosing resistor values high enough to make damage to any active components unlikely.
- Draw the schematic diagram for the circuit to be analyzed.
- Carefully build this circuit on a breadboard or other convenient medium.
- Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
- Mathematically analyze the circuit, solving for all voltage and current values.
- Carefully measure all voltages and currents, to verify the accuracy of your analysis.
- If there are any substantial errors (greater than a few percent), carefully check your circuit’s construction against the diagram, then carefully re-calculate the values and re-measure.
When students are first learning about semiconductor devices, and are most likely to damage them by making improper connections in their circuits, I recommend they experiment with large, high-wattage components (1N4001 rectifying diodes, TO-220 or TO-3 case power transistors, etc.), and using dry-cell battery power sources rather than a benchtop power supply. This decreases the likelihood of component damage.
As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading” (on the high end) and to avoid transistor burnout (on the low end). I recommend resistors between 1 kΩ and 100 kΩ.
Reveal answerLet the electrons themselves give you the answers to your own “practice problems”!
Notes:It has been my experience that students require much practice with circuit analysis to become proficient. To this end, instructors usually provide their students with lots of practice problems to work through, and provide answers for students to check their work against. While this approach makes students proficient in circuit theory, it fails to fully educate them.
Question 2 of 21
What type of electronic component do these symbols represent, and what special function does it perform?
Reveal answerThese are varistors. Sometimes they are referred to by the acronym MOV, which stands for Metal Oxide Varistor. I’ll let you research what is unique about the behavior of these devices.
Follow-up question: plot an approximate graph of current versus voltage for a varistor, and comment on how this compares to the current/voltage characteristic of a normal resistor.
Notes:Ask your students to reveal their information sources used when researching varistors, and also if they were able to determine how these devices are constructed.
Question 3 of 21
Explain how a surge protector functions: the kind of device used to protect electronic equipment against common power line voltage transients. Draw a schematic diagram to accompany your explanation.
Reveal answerSome surge protectors use varistors, others use zener diodes, and others use more advanced technologies. I’ll let you research designs and schematic diagrams on your own!
Notes:Ask students how a surge protector (or surge “suppressor”) is similar in principle to clipper circuits used for small electronic signals.
