DC Electric Circuits
DC Metrology
  • Question 1
    Define the following metrological terms:
    • Uncertainty
    • Accuracy
    • Error
    • Precision
    • Traceability
    Reveal answer
  • Question 2
    In chemistry laboratories, balance scales are used to precisely measure the mass of various substances. How, exactly, is a laboratory “balance” scale used? What component of the scale primarily determines its accuracy?
    Reveal answer
  • Question 3
    Explain how this electrical system functions in a similar manner to a laboratory “balance” scale:
    The circle with the letter “G” in it is a symbol for a galvanometer. What practical purpose might a system like this serve?
    Reveal answer
  • Question 4
    If a voltmeter is to be used to directly measure the voltage of an unknown source, it must first be calibrated so as to ensure an accurate measurement:
    What is the minimum number of points along the meter’s range that it needs to be calibrated at, given the assumption of perfectly linear response?
    If a voltmeter is to be used to measure the voltage of an unknown source, as a differential indicator only, what is the minimum number of points along its range that it needs to be calibrated at?
    Reveal answer
  • Question 5
    Explain the simplest way to perform a single-point calibration on a highly sensitive, precision voltmeter. How do you ensure the voltmeter is receiving a fixed input of known quantity, especially without having expensive calibration equipment available?
    Reveal answer
  • Question 6
    This voltage divider should output half the battery’s voltage between points A and B:
    However, if you perform this same experiment using a real voltmeter, the measurement obtained with the meter will be substantially different from what should be there, based on a prediction of 1/2Ebattery. Explain why the voltmeter registers as it does. What is it about this circuit that causes the measurement to be so far off from the prediction, when we know full well that other voltage divider circuits we’ve constructed do not exhibit any significant error?
    Reveal answer
  • Question 7
    The following voltmeter circuit avoids problems of “loading” when measuring high-resistance voltage sources. Describe how to operate this circuit, and how loading error is eliminated by using such a potentiometric instrument:
    Reveal answer
  • Question 8
    General metrology used to be based upon standard artifacts, but the modern scientific trend is toward intrinsic standards. Explain what these two terms mean, as well as their significance in scientific work.
    Reveal answer
  • Question 9
    What technology is currently regarded as state-of-the-art for reproducing the standard volt?
    Reveal answer
  • Question 10
    What technology is currently regarded as state-of-the-art for reproducing the standard ohm?
    Reveal answer
  • Question 11
    Calibration laboratories often make reference to Test Uncertainty Ratios (TUR’s), normally holding to a ratio of 4:1 or more when performing calibration work on instruments. What does this figure mean?
    Reveal answer
