Discrete Semiconductor Devices and Circuits
IGFET Amplifiers
Question 1
Don’t just sit there! Build something!! Learning to mathematically analyze circuits requires much study and practice. Typically, students practice by working through lots of sample problems and checking their answers against those provided by the textbook or the instructor. While this is good, there is a much better way.
- Carefully measure and record all component values prior to circuit construction, choosing resistor values high enough to make damage to any active components unlikely.
- Draw the schematic diagram for the circuit to be analyzed.
- Carefully build this circuit on a breadboard or other convenient medium.
- Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
- Mathematically analyze the circuit, solving for all voltage and current values.
- Carefully measure all voltages and currents, to verify the accuracy of your analysis.
- If there are any substantial errors (greater than a few percent), carefully check your circuit’s construction against the diagram, then carefully re-calculate the values and re-measure.
When students are first learning about semiconductor devices, and are most likely to damage them by making improper connections in their circuits, I recommend they experiment with large, high-wattage components (1N4001 rectifying diodes, TO-220 or TO-3 case power transistors, etc.), and using dry-cell battery power sources rather than a benchtop power supply. This decreases the likelihood of component damage.
As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading” (on the high end) and to avoid transistor burnout (on the low end). I recommend resistors between 1 kΩ and 100 kΩ.
Reveal answerLet the electrons themselves give you the answers to your own “practice problems”!
Notes:It has been my experience that students require much practice with circuit analysis to become proficient. To this end, instructors usually provide their students with lots of practice problems to work through, and provide answers for students to check their work against. While this approach makes students proficient in circuit theory, it fails to fully educate them.
Question 2
A common means of biasing a depletion-type IGFET is called zero biasing. An example circuit is shown below:
This may appear similar to self-biasing as seen with JFET amplifier circuits, but it is not. Zero biasing only works with IGFET amplifier circuits. Explain why this is so.
Reveal answerThe natural Q-point of a depletion-type IGFET occurs with a gate-to-source voltage of 0 volts. This is very different from either bipolar junction (BJT) or junction field-effect (JFET) transistors.
Follow-up question: will “zero” biasing work with enhancement-mode IGFETs as well? Explain why or why not.
Notes:This question provides students with an opportunity to review IGFET theory, and to differentiate between depletion-mode and enhancement-mode types, which is a subject of much confusion among students new to the topic.
Question 3
One method used to bias enhancement-mode IGFETs is drain-feedback biasing. An example is shown here:
Another method of biasing enhancement-mode IGFETs is the voltage divider technique, which should be familiar to you from your understanding of BJT amplifier circuits:
How do you think the performance of these two differently-biased circuits compare? Assuming they were both biased for the same Q-point, would there be any significant difference(s) in their signal amplifying performance? Why or why not?
Reveal answerOne of these circuits has the potential for much greater voltage gain. I’ll let you determine which one, and more importantly, why.
Notes:This question is a good test of your students’ comprehension of feedback in transistor circuits: what it is, what causes it, and what its effects are.
Ask your students whether they think the technique of drain-feedback biasing would work in a depletion-mode IGFET amplifier circuit.
