Analog Integrated Circuits
Linear Computational Circuitry
35 questions By Tony R. Kuphaldt
Page 1 of 12 0 of 35 answers revealed (0%)
  • Question 1 of 35
    Don’t just sit there! Build something!!
    1. Carefully measure and record all component values prior to circuit construction.
    2. Draw the schematic diagram for the circuit to be analyzed.
    3. Carefully build this circuit on a breadboard or other convenient medium.
    4. Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
    5. Mathematically analyze the circuit, solving for all voltage and current values.
    6. Carefully measure all voltages and currents, to verify the accuracy of your analysis.
    7. If there are any substantial errors (greater than a few percent), carefully check your circuit’s construction against the diagram, then carefully re-calculate the values and re-measure.
    Avoid using the model 741 op-amp, unless you want to challenge your circuit design skills. There are more versatile op-amp models commonly available for the beginner. I recommend the LM324 for DC and low-frequency AC circuits, and the TL082 for AC projects involving audio or higher frequencies.
    As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading”. I recommend resistor values between 1 kΩ and 100 kΩ.
    Reveal answer
  • Question 2 of 35
    Suppose I set a potentiometer to the 30% position, so that the wiper is 30% of the way up from the bottom:
    Describe the mathematical relationship between Vin and Vout with the potentiometer in this position. What does this suggest about the usefulness of a potentiometer as an analog computational element?
    Reveal answer
  • Question 3 of 35
    What historical significance does the name “operational amplifier” have? Of course, it should be obvious that these devices are amplifiers, but what is meant by the word operational?
    Reveal answer
Related Tools:
