Don’t just sit there! Build something!! |
When students are first learning about semiconductor devices, and are most likely to damage them by making improper connections in their circuits, I recommend they experiment with large, high-wattage components (1N4001 rectifying diodes, TO-220 or TO-3 case power transistors, etc.), and using dry-cell battery power sources rather than a benchtop power supply. This decreases the likelihood of component damage.
As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading” (on the high end) and to avoid transistor burnout (on the low end). I recommend resistors between 1 kΩ and 100 kΩ.
Let the electrons themselves give you the answers to your own “practice problems”!
When plotted on a curve tracer, the characteristic curve for a normal PN junction rectifying diode looks something like this:
Label each axis (horizontal and vertical) of the curve tracer graph, then determine whether the diode behaves more like a voltage source or more like a current source (i.e. does it try to maintain constant voltage or does it try to maintain constant current?) when it is conducting current.
Models are very useful because they simplify circuit approximations. For example, we can analyze this diode circuit quite easily if we substitute an electrical source in place of the diode:
The only question here is, which substitution makes the most sense? Based on the diode’s characteristic curve behavior, should we substitute a voltage source or a current source in place of it? Assuming this is a 1N4001 rectifying diode, what is the value we should use for the substituting source?
This behavior is similar to that of a voltage source once it is forward-biased and conducting current.
Follow-up question: quite obviously, diodes do not behave exactly as voltage sources. You cannot power anything off of a diode, for instance! Identify some of the limitations inherent to modeling diodes as voltage sources. Are there any instances you can think of where such a model could be misleading?
Modeling nonlinear semiconductor components in terms of linear, idealized passive components is a time-honored “trick” used to simplify circuit analysis. Like all “tricks” and analogies, this one has definite limitations. The follow-up question’s hint practically gives away examples of where such a model could be misleading!
The following schematic diagram is of a simple curve tracer circuit, used to plot the current/voltage characteristics of different electronic components on an oscilloscope screen:
The way it works is by applying an AC voltage across the terminals of the device under test, outputting two different voltage signals to the oscilloscope. One signal, driving the horizontal axis of the oscilloscope, represents the voltage across the two terminals of the device. The other signal, driving the vertical axis of the oscilloscope, is the voltage dropped across the shunt resistor, representing current through the device. With the oscilloscope set for “X-Y” mode, the electron beam traces the device’s characteristic curve.
For example, a simple resistor would generate this oscilloscope display:
A resistor of greater value (more ohms of resistance) would generate a characteristic plot with a shallower slope, representing less current for the same amount of applied voltage:
Curve tracer circuits find their real value in testing semiconductor components, whose voltage/current behaviors are nonlinear. Take for instance this characteristic curve for an ordinary rectifying diode:
The trace is flat everywhere left of center where the applied voltage is negative, indicating no diode current when it is reverse-biased. To the right of center, though, the trace bends sharply upward, indicating exponential diode current with increasing applied voltage (forward-biased) just as the “diode equation” predicts.
On the following grids, plot the characteristic curve for a diode that is failed shorted, and also for one that is failed open:
Characteristic curves are not the easiest concept for some students to grasp, but they are incredibly informative. Not only can they illustrate the electrical behavior of a nonlinear device, but they can also be used to diagnose otherwise hard-to-measure faults. Letting students figure out what shorted and open curves look like is a good way to open their minds to this diagnostic tool, and to the nature of characteristic curves in general.
Although it is far from obvious, one of the oscilloscope channels will have to be “inverted” in order for the characteristic curve to appear in the correct quadrant(s) of the display. Most dual-trace oscilloscopes have a “channel invert” function that works well for this purpose. If engaging the channel invert function on the oscilloscope flips the wrong axis, you may reverse the connections of the test device to the curve tracer circuit, flipping both axes simultaneously. Between reversing device connections and reversing one channel of the oscilloscope, you can get the curve to plot any way you want it to!
How is it possible to determine the polarity of a rectifying diode (which terminal is the anode, and which terminal is the cathode) from its physical appearance?
I’ll give you a hint: there is a stripe (similar to a color band on a resistor) closer to one end of the diode than the other!
The answer to this question, if not found in a book, may be easily determined by direct experimentation. I recommend students verify information about electronics through experimentation whenever possible, and not rely solely on someone else’s documentation.
The “1N400x” series of rectifying diodes are very popular for low-current applications. By “1N400x,” I mean the 1N4001, 1N4002, 1N4003, . . . 1N4007. Only one parameter differs between these different diode models. What parameter is this, and what is its significance?
Only the reverse (or blocking) voltage rating differs between these diode models.
Be sure to ask your students where they found the information on these different diode models!
Discuss with your students the importance of this rating, and why a person might choose the 1N4007 diode for an application rather than the 1N4001, for instance.
Complete the following table of values for this diode circuit, assuming a typical forward voltage drop of 0.65 volts for the diode:
Have your students explain all their steps and calculations for solving this problem, so that you and their classmates can examine their problem-solving processes in an open and constructive forum.
Complete the following table of values for this diode circuit, assuming a typical forward voltage drop of 0.72 volts for the diode:
Predict how all component voltages and currents in this circuit will be affected as a result of the following faults. Consider each fault independently (i.e. one at a time, no multiple faults):
For each of these conditions, explain why the resulting effects will occur.
The purpose of this question is to approach the domain of circuit troubleshooting from a perspective of knowing what the fault is, rather than only knowing what the symptoms are. Although this is not necessarily a realistic perspective, it helps students build the foundational knowledge necessary to diagnose a faulted circuit from empirical data. Questions such as this should be followed (eventually) by other questions asking students to identify likely faults based on measurements.
An important parameter for many semiconductor components is thermal resistance, usually specified in units of degrees Celsius per Watt. What does this rating mean, and how is it related to temperature?
“Thermal resistance” is a measure of the heat differential required for a semiconductor component to dissipate a given amount of power.
Discuss the nature of heat with your students: that a differential temperature (∆T) is required for transfer of heat through a medium such as a solid. Compare this phenomenon with differences of electrical potential (E) and electric current (I). How do we express an electrical conductor’s ability to carry a moving charge under the influence of a potential difference?
Ask your students what difference it makes whether a semiconductor component has a high or a low thermal resistance. What is ideal for a semiconductor device, a high thermal resistance or a low thermal resistance? Why?
Rectifying diodes, like many other types of semiconductor components, should be derated at elevated ambient temperatures. Datasheets often provide “derating curves” that prescribe the maximum current for a range of ambient temperatures.
Explain just what “derating” is, and why it is so important for semiconductor devices.
“Derating” means to downgrade the maximum power rating of a component, in a response to changes in other factors affecting the component’s operation.
Discuss with your students why temperature is such a critical factor in semiconductor component operation. What happens to a semiconductor junction when it is heated? What may happen if it is heated too much?
Describe the operation of this diode testing circuit:
Identify what the two light-emitting diodes (LEDs) will do when testing these three types of diodes:
Challenge question: this circuit not only detects the presence of a good diode, but it also has the ability to identify that diode’s polarity (which terminal is the cathode, and which terminal is the anode). Explain how the circuit is able to do this.
This simple yet ingenious circuit (not my design, lest you think I’m conceited) serves the purpose of illustrating diode rectification behavior, and provides a potential project for students to build and test.
A useful piece of test equipment for semiconductor components is a curve tracer, used to produce current/voltage graphs for a component being tested. The graphs are typically displayed on an oscilloscope screen. Here is a very simple curve tracer circuit, designed to be used with an oscilloscope in X-Y mode:
Describe what type of trace would be drawn by this circuit on an oscilloscope screen if a resistor was being tested. Then, show the trace for a normal rectifying diode.
Challenge question: does it matter whether or not the AC source voltage for this circuit is perfectly sinusoidal?
There is a lot to discuss in this question. Not only does the concept of “curve tracing” merit attention, but the specific operation of this circuit is worthy of investigation as well. The reason I asked students to determine the “curve” for a resistor was to introduce them to the idea of graphing component current/voltage functions, and also to allow them to analyze the circuit with a more linear component under test than a semiconductor.
An important question to ask here is why channel Y of the oscilloscope must be inverted to obtain the graphs shown. What would the graphs look like if the channel were not inverted?
The challenge question may be rephrased as, ïs the excitation voltage waveshape critical to obtaining a precise curve?” One way to demonstrate this is to use a function generator as the excitation voltage source (a transformer may be necessary to isolate the function generator ground from the oscilloscope ground!), and to try different waveshapes, watching the responses on the oscilloscope screen.
Suppose we have an application where a DC generator provides power to charge a secondary-cell battery:
The only problem with this setup is, the generator tries to act as a motor when the engine turning it is shut off, drawing power from the battery and discharging it. How could we use a rectifying diode to prevent this from happening?
This question provides a good opportunity to review the direction of current through a battery when charging, versus when discharging. It also shows a way we can prevent the generator from “motoring” without having to use a reverse-current relay.
What could you do if you had an application for a rectifying diode that required a forward current rating of 2.5 amps, but you only had model 1N4001 diodes available to use? How could you use multiple 1N4001 rectifying diodes to handle this much current?
Use three 1N4001 diodes connected in parallel, like this:
Follow-up question: while this solution should work (in theory), in practice one or more of the diodes will fail prematurely due to overheating. The fix for this problem is to connect “swamping” resistors in series with the diodes like this:
Explain why these resistors are necessary to ensure long diode life in this application.
The answer to this question should not be much of a challenge to your students, although the follow-up question is a bit challenging. Ask your students what purpose the swamping resistors serve. What do we know about current through the diodes if one or more of them will fail due to overheating without the swamping resistors?
What value of resistor would your students recommend for this application? What factors influence their decision regarding the resistance value?
Suppose you were building a simple half-wave rectifier circuit for a 480 volt AC source. The diode needs to withstand the full (peak) voltage of this AC source every other half-cycle of the waveform, or else it will fail. The bad news is, the only diodes you have available for building this rectifier circuit are model 1N4002 diodes.
Describe how you could use multiple 1N4002 rectifying diodes to handle this much reverse voltage.
Use seven 1N4002 diodes connected in series, like this:
Follow-up question: while this solution should work (in theory), in practice one or more of the diodes will fail prematurely due to overvoltage. The fix for this problem is to connect “divider” resistors in parallel with the diodes like this:
The answer to this question should not be much of a challenge to your students, although the follow-up question is a bit challenging. Ask your students what purpose the divider resistors serve. What do we know about voltage dropped across the diodes if one or more of them will fail without the divider resistors in place?
What diode performance parameter establishes the limit for maximum frequency of AC which it may rectify? If you were to examine a diode datasheet, what parameter (or parameters) would be the most important in answering this question?
Reverse Recovery Time (trr) is a very important parameter limiting maximum rectification frequency. Junction capacitance (Cj) is another.
Ask your students to describe what the “ideal” trr and Cj values would be for a diode with unlimited rectification bandwidth.
Find one or two real diodes and bring them with you to class for discussion. Identify as much information as you can about your diodes prior to discussion:
If possible, find a manufacturer’s datasheet for your components (or at least a datasheet for a similar component) to discuss with your classmates.
Be prepared to prove the forward voltage drop of your diodes in class, by using a multimeter!
The purpose of this question is to get students to kinesthetically interact with the subject matter. It may seem silly to have students engage in a “show and tell” exercise, but I have found that activities such as this greatly help some students. For those learners who are kinesthetic in nature, it is a great help to actually touch real components while they’re learning about their function. Of course, this question also provides an excellent opportunity for them to practice interpreting component markings, use a multimeter, access datasheets, etc.
by Jake Hertz
by Jake Hertz
by Ikimi .O
