Skyworks Solutions IoT Front End Modules | New Product Brief
Skyworks’ SKY66119 is a 460 MHz transmit/receive front-end module that provides high performance and a simpler design for a variety of applications.
New Product July 27, 2018 by Mouser
Skyworks IoT Front End Modules
Skyworks’ SKY66119 is a 460 MHz transmit/receive front-end module that provides high performance and a simpler design for applications such as automated meter reading, advanced metering infrastructure, and other ISM systems. The SKY66119 integrates a high-efficiency power amplifier, low noise amplifier, antenna switch, 50 Ω RF matching and bias circuits, and control logic in a 28-pin MCM. Transmit power is controlled with an analog voltage, with output power up to +30.5 dBm. The receive path provides a low total noise figure of 1.7 dB and 15 dB gain. All RF ports are internally DC blocked and an external filter can be inserted into the receive path. Skyworks’ SKY61119 also supports shutdown and amplifier bypass modes.
  • High-efficiency PA, LNA, 50 Ω RF match and bias circuits, control logic
  • Package: 28-pin MCM, 6 mm x 6 mm
  • Analog power control: 0 VDC to 2.5 VDC
  • TX Output Power: up to +30.5 dBm
  • RX path NF: < 1.8 dB
  • Control logic: Shutdown, PA bypass, LNA bypass
More Information
