TE Connectivity KMXP Series AMR Position Sensor | Tech Specs
The TE Connectivity KMXP Series AMR Position Sensor allows for greater design freedom by providing reliable and accurate measurements in harsh environments.
The TE Connectivity KMXP series position sensors enable measurements with an accuracy of 10 to 50 microns, harnessing sub-micron resolution when used in linear measurements. The KMXP is a magnetoresistive sensor, so it isn’t affected by common contaminants, and it can operate at temperatures up to 150 degrees Celsius, making it ideal for the harshest environments.
The sensor is housed in a DFN package, so it can easily be integrated into end applications, with perpendicular and flat solderable variants available for more design freedom. TE’s KMXP series position sensors are offered with 1mm to 5mm pole pitch, an ideal position sensing solution for industrial machinery, medical devices, and industrial robotics.
- Accuracy: 10-50 µm
- Sub-µm resolution for linear use
- Type: magnetic linear position sensor
- Operating Temp Range: -40°C to 150°C
- Package: DFN2x6, perpendicular or flat solderable
- Pole pitch: 1mm to 5mm
