Toshiba SSM6K Silicon N-Channel Small Signal MOSFETs | New Product Brief
Toshiba SSM6K Silicon N-Channel Small Signal MOSFETs are compact, low-profile, and designed for use in power management and high-speed switching in small, mobile devices.
New Product May 24, 2017 by Mouser Electronics
Toshiba SSM6K Silicon N-Channel Small Signal MOSFETs are compact, low-profile, and designed for use in power management and high-speed switching in small, mobile devices. The SSM6K are available with a VDSS range of 12 to 60 V and have RDS,ON as low as 6.5 mΩ, but still support drain power dissipation from 500 mW to 1 W. The low on-resistance reduces heat dissipation by up to 40% versus competing devices.
Multiple packages are available, including the ultra-small WCSP6C package that measures 1.5 x 1.0 x 0.5 mm with a 0.5 mm pitch. Toshiba SSM6K series of N-Channel MOSFETs are suitable for load switching applications over 10 W, including devices using USB Type-C and USB Power Delivery standards.
  • VDSS: 12 V to 60 V
  • Continuous drain current: Up to 15 A
  • Drain power dissipation: 500 mW to 1 W
  • Channel temperature: 150°C
  • RDS,On: 6.5 mΩ to 400 mΩ
  • Packages: UDFN6B-6, ES6-6, UF6-6, WCSP6C-6
More Information
