Volume
Designing Analog Chips
Chapter
Analog Measurements
PDF Version
Decibels for Voltage and Power Ratios
Analog scales tend to be very large. As an example, the hearing threshold of a young adult is 20 micro-Pascal; the maximum level without damaging the ear can be more than 20 Pascal, a ratio of one to 1 million. Particularly because of the widely varying sound levels, a need for a logarithmic measure appeared early on in electronics.
The Neper, Bel, and Decibel
There are two logarithmic measures: the neper and the bel. The neper is based on the natural logarithm and named after John Napier, a 16th-century Scottish mathematician who came up with the logarithmic table. “Neper” is the Latinized spelling of his name.
In the 1920s, a measure based on logarithm with base 10 began to be used at Bell Laboratories. At first called the "transmission unit," it was subsequently re-christened the bel, after Alexander Graham Bell.
The idea of this unit is simple. A bel is the logarithm of two power levels:
$$\text{bel} ~=~ \log \frac{P_1}{P_2}$$
However, the bel turned out to be a bit coarse. One-tenth of a bel suited the Bell Labs people better, hence the decibel (dB):
$$\text{dB} ~=~ 10\log \frac{P_1}{P_2}$$
This is the ratio of two power levels. Since power is related to the square of the voltage, we get:
$$\text{dB} ~=~ 20 \log \frac{V_1}{V_2}$$
The neper has more or less disappeared as a measure, decibels having proved more convenient. When using decibels, however, always keep in mind there’s a 2:1 difference between the ratios of power and those of voltages or currents (or pressure, for that matter).
Even though a logarithmic ratio is very convenient, it’s helpful to picture the actual voltage ratios as described in Table 1.
Table 1. Decibel levels and their corresponding voltage ratios.
Decibel level Voltage ratio
–60 dB 1/1,000
–40 dB 1/100
–20 dB 1/10
–6 dB Approximately 0.5, or exactly 0.5012
–3 dB 0.707
0 dB 1
20 dB 10
40 dB 100
60 dB 1,000
Variations on the Decibel
Fundamentally, decibels are relative, expressing only a ratio. But there are many modifications in which one of the two levels is a fixed, absolute value. Here are a few important examples:
  • dB SPL: Sound pressure level where the hearing threshold (0 dB) is based on 20 μPA.
  • dBμV: Voltage ratio relative to 1 μV.
  • dBm: Power ratio where 0 dB = 1 mW.
Originally, dBm was based on an impedance of 600 Ω (that of a telephone line). It’s now used with any impedance, which is fine as long as we calculate power ratios and not voltage ratios.
