Vishay T52 vPolyTanTM Polymer Surface Mount Capacitors | Tech Specs
Vishay's range of T52 vPolyTanTM Polymer Surface Mount capacitors offer everything from 0402 to 225 models and are specifically designed for large body MLCCs. With C0G and X7R dielectrics and voltage capacity ratings up to 1000 volts, designers can easily find what they need.
New Product December 21, 2018 by TTI, Inc
Vishay’s T52 series of vPolyTan™ Polymer Surface Mount Chip Capacitors can go really low. Available in case sizes with a profile as low as 1.5mm, the capacitors are ideal for applications requiring large bulk capacitance such as SSDs, motherboards, docking stations, and more. They’re designed without a lead-frame and use L-shaped facedown terminations. T52 series capacitors are also 100% surge current tested and have very low ESR. Capacitance values range from 47 to 470 microfarads with a 20% tolerance, with voltage ratings from 10 to 35 volts DC and a specified operating temperature of negative 55 to positive 105 degrees Celsius.
  • Low profile: 1.5mm or 2.0mm
  • Lead-frameless molded case: EIA sizes 7343-15 and 7343-20
  • 100% surge current tested
  • Capacitance Range: 47μF to 470μF
  • Voltage Rating: 6.3VDC to 35VDC
  • Operating Temperature: -55°C to +105°C
More Information
