Gigadevice Rolls Out New High-Performance Industrial MCU Series
The new microcontroller portfolio is built on a unified architecture with tailored IP for key industrial applications.
News November 25, 2026 by Duane Benson
Gigadevice recently introduced a new industrial MCU line to meet growing demands within industrial automation. The GD32H7 series is based on a single-die common silicon platform that can be tailored with application-specific IP. This common silicon reduces costs and enables greater hardware and software commonality.
At the heart is a 600-MHz or 750-MHz 32-bit Arm Cortex-M7 and 640-KB CPU-synchronous tightly coupled memory (TCM). TCM is an increasingly common feature in real-time and industrial MCUs because of the performance and responsiveness gains it delivers. TCM in the GD32H7 runs at the CPU clock speed and supports zero-wait-state instruction and data execution.
The product line also includes a hardware math accelerator to enhance motor control, signal analysis, and algorithm computation. It covers advanced math such as motor control-oriented trigonometric functions, fast Fourier transform (FFT), and finite impulse response (FIR) filtering. Gigadevice reports a Coremark score of 3,736 for the MCUs.
Simone Medardoni
Simone Medardoni, technical marketing manager at GigaDevice Semiconductor shows us the GD32H7 MCU demo at the company's Electronica booth..
Common Core Feature Set
Gigadevice has outfitted the new line with application-specific features to cover the most common high-performance industrial automation segments, but the core feature set remains common across all variants. All MCUs share the same processor core, memory architecture, and base peripheral set. The main differentiation comes from the tailored feature set for each sub-line.
The MCUs include up to 2 MB of high-speed executable flash, up to 8 MB of storage flash, and up to 1.2 MB of high-speed SRAM. The parts also support external memory in a 200 MHz double data rate mode. In addition to common memory, the line supports industrial communication protocols such as dual 10/100 Mbps Ethernet, three CAN-FD buses, USB HS/FS, and SDIO. It also includes common device-to-device protocols such as U(S)ART, I2C, SPI, and I2S. It offers multiple A/D and D/A interfaces and 16-, 32-, and 64-bit timers. The chips operate from 1.71 V to 3.6 V.
The GD32H7 at GigaDevice's booth.
The full product line is certified to IEC 61508 SC3 (SIL 2 and SIL 3) for functional safety. It has integrated AES encryption, SHA-256 hash verification, and a true random number generator. A hardware-unique chip ID supports inventory control, revision control, and authentication. Gigadevice designed the overall security with EU Cyber Resilience Act (CRA) requirements in mind.
Targeted Industrial Applications
While the core processing capabilities remain the same because of the single-die common silicon platform, each segment of the product line includes a set of interfaces and extra peripherals suited to different classes of industrial uses.
Robotic Joint and Servo Control
The GD32H77R tops out at 600 MHz and comes outfitted for servo drive and robot joint applications. To meet the space constraints common in such devices, the chip is packaged in a 9 mm x 9 mm BGA169 package. It also integrates an EtherCAT slave controller and multiple-standard encoder interfaces. It natively supports encoder interfaces such as EnDat, BiSS-C, and Tamagawa, reducing the need for software or custom encoder hardware. It includes an RDCM resolver-to-digital conversion module to assist with sensor interpretation and speed and position management.
Industrial HMI Applications
The GD32H7xD series, including the GD32H78D and GD32H77D models, is designed for display-oriented embedded human-machine interface (HMI) devices such as handheld gimbals, audio interfaces, medical devices, and other smart home and smart industry devices. It includes a mobile industry processor interface (MIPI) display serial interface (DSI), TFT LCD interface, serial audio interface (SAI), SPDIF, and PGDM microphone interfaces. It rounds the display support out with an image processing accelerator. The 78D variants clock at up to 750 MHz while the 77D units top out at 600 MHz.
Industrial Automation, General-Purpose, and Real-Time Motion Control
The GD32H7xE units (GD32H78E 750 MHz models and GD32H77E 600 MHz models) include features needed for high-precision, real-time motion control. The 7xE variants integrate a hardware EtherCAT slave controller with DC synchronization accuracy up to 62.5 μs. EtherCAT is designed for ultra-fast response times. It is fast enough to be considered a deterministic communications protocol, as is needed in the most demanding real-time industrial applications. These applications include programmable logic controllers, high-speed multi-axis synchronization, and servo control.
The final members of the portfolio, the GD32H7x9 (GD32H789 750 MHz models and GD32H779 600-MHz models), offer a diverse enough feature set to serve as a general-purpose, high-end industrial microcontroller.
Unified Hardware Foundation
Gigadevice designed a unified silicon platform to deliver lower cost and greater hardware and software commonality across a broad set of applications. Combining a powerful general-purpose MCU with common-hardware dedicated MCU variants enables more efficient single-platform/multi-node development. This commonality reduces supply chain risk and the need to support multiple software toolchains. The chips utilize the Gigadevice GD32 Eclipse IDE and are compatible with third-party tools from Arm, Keil, IAR, and Segger.
Samples are expected in January 2027, with full production launching in April 2027.
