A Four-Channel RS-422 Differential Line Driver Module
This project brief describes how to implement a four-channel differential line driver module for reliable long-distance data transmission over balanced twisted-pair lines.
This Quadruple Differential Line Driver module provides four independent differential output channels for driving balanced transmission lines in industrial and embedded applications. Built around the Texas Instruments AM26LS31 IC in a DIP-16 package, the module meets TIA/EIA-422-B and ITU standards. It delivers high-current 3-state outputs capable of driving twisted-pair or parallel-wire transmission paths. In my next project, I will show you how to build the complementary four-channel RS-422 differential line receiver.
Figure 1. Assembled AM26LS31 Quadruple Differential Line Driver
module.
Figure 1. Assembled AM26LS31 Quadruple Differential Line Driver module.
An onboard LM7805C regulator accepts 7–18V DC input and supplies a stable 5V rail to the driver IC. The assembled module is shown in Figure 1.
All four driver channels share a common enable circuit with both active-high (G) and active-low (!G) enable inputs, brought out to solder jumpers on the back of the PCB. This flexibility allows the module interface to communicate directly with microcontrollers or PLCs regardless of the enable polarity.
Screw terminals (5.08 mm pitch) connect the four differential output pairs to a transmission cable, while an 8-pin header provides the digital data inputs at 2.54 mm pitch for easy breadboard or jumper-wire connection.
When power is removed, the 3-state output stage automatically places all outputs in a high-impedance condition, preventing bus loading in multi-drop configurations. The module targets applications including industrial encoder interfaces, fieldbus sensor transmitters, Modbus temperature controllers, and motor control systems where data integrity over cable runs is critical.
Specs and Features
  • Supply voltage: 7–18 VDC
  • 4-channel differential output (TIA/EIA-422-B / ITU compliant)
  • Key IC: AM26LS31 (DIP-16, Bi-CMOS)
  • 3-state outputs with high-impedance power-off condition
  • Active-high (G) and active-low (!G) enable inputs via solder jumpers
  • Onboard 5 V regulator: LM7805C (TO-220), with reverse-polarity diode protection
  • Output screw terminals: 5.08 mm pitch (CN1, CN4, CN5, CN7)
  • Digital input header: 8-pin, 2.54 mm pitch (CN3)
  • Power LED indicator
  • PCB dimensions: 46.36 × 30.48 mm
  • Four 3 mm mounting holes
How It Works
The AM26LS31 contains four independent differential line drivers. The functional block diagram in Figure 2 shows the internal structure of the AM26LS31.
Figure 2. AM26LS31 functional block diagram showing four differential
driver channels and shared enable logic.
Figure 2. AM26LS31 functional block diagram showing four differential driver channels and shared enable logic. Image used courtesy of Texas Instruments
Each path produces a complementary output pair (Y true, Z inverted) from a single-ended TTL/CMOS logic input. Bi-CMOS circuitry keeps quiescent current low while maintaining the fast edge rates required for long-cable RS-422 transmission.
The 3-state control is shared across all four channels: a logic high on the G pin or a logic low on the !G pin enables the outputs. When neither condition is met, all outputs enter a high-impedance state.
Schematic and Bill of Materials
The schematic in Figure 3 shows the full circuit. The AM26LS31 (U1) is powered from the regulated 5 V rail. Channel inputs arrive at CN3 (SIP8 header), and the four differential output pairs connect to screw terminals CN1, CN4, CN5, and CN7.
Figure 3. Schematic for the AM26LS31 Quadruple Differential Line
Driver module.
Figure 3. Schematic for the AM26LS31 Quadruple Differential Line Driver module.
On U1, G and !G are renamed EN and !EN and connected to VCC and GND, respectively, via solder jumpers J1 and J2. This enables all channels by default. Cutting a jumper allows external logic control.
The power supply path runs from the CN8 input header through a 1N4007 reverse-polarity protection diode (D2) to the LM7805C linear regulator (U2). Bypass capacitors C1 (100 nF) and C2 (10 µF) filter the regulated 5V output. A 1 kΩ current-limiting resistor (R1) and red LED (D1) provide a power-on indicator.
The bill of materials is shown in Table 1.
Table 1. BOM for AM26LS31 Quadruple Differential Line Driver.
REF DESCRIPTION QTY MFG SUPPLIER PART NO.
CN1, CN4, CN5 Pin screw terminal, pitch 5.08 mm 3 PHOENIX DigiKey 277-1247-ND
CN3 8-pin male header, pitch 2.54 mm 1 WÜRTH DigiKey 732-5321-ND
CN6 2-pin male header, pitch 2.54 mm 1 WÜRTH DigiKey 732-5315-ND
CN7 3-pin screw terminal, pitch 5.08 mm 1 PHOENIX DigiKey 277-1248-ND
CN8 4-pin male header, pitch 2.54 mm 1 WÜRTH DigiKey 732-5317-ND
C1 100 nF/25V ceramic SMD 0805 1 YAGEO/MURATA DigiKey
C2 10 µF/25V ceramic SMD 0805 1 YAGEO/MURATA DigiKey
D1 LED red SMD 0805 1 OSRAM DigiKey 475-1278-1-ND
D2 1N4007 SMD 1 Diode Inc. DigiKey S1MBDITR-ND
J1, J2 PCB solder jumper (3-pad) 2 — —
R1 1 kΩ 5% SMD 0805 1 YAGEO/MURATA DigiKey
U1 AM26LS31, DIP-16 1 TI DigiKey 296-1374-5-ND
U2 LM7805C/TO-220 1 ST DigiKey 497-1443-5-ND
Connections
The connection diagram in Figure 4 shows all input and output assignments. CN8 accepts the 7–18 VDC supply. CN3 receives the four digital channel inputs.
Figure 4. Connection diagram for the AM26LS31 module [click to
enlarge].
Figure 4. Connection diagram for the AM26LS31 module.
CN1 — Channel A Output (2-pin screw terminal, 5.08 mm pitch):
  • Pin 1 = Channel A+ OUT
  • Pin 2 = Channel A– OUT
CN2 — DNP (Do Not Populate)
CN3 — Digital Input Header (8-pin, 2.54 mm pitch):
  • Pin 1 = Channel A Input
  • Pin 2 = GND
  • Pin 3 = Channel B Input
  • Pin 4 = GND
  • Pin 5 = Channel C Input
  • Pin 6 = GND
  • Pin 7 = Channel D Input
  • Pin 8 = GND
CN4 — Channel B Output (2-pin screw terminal, 5.08 mm pitch):
  • Pin 1 = Channel B+ OUT
  • Pin 2 = Channel B– OUT
CN5 — Channel C Output (2-pin screw terminal, 5.08 mm pitch):
  • Pin 1 = Channel C+ OUT
  • Pin 2 = Channel C– OUT
CN6 — 5V DC Output Header (2-pin, 2.54 mm pitch):
  • Pin 1 = 5V DC
  • Pin 2 = GND
CN7 — Channel D Output (3-pin screw terminal, 5.08 mm pitch):
  • Pin 1 = Channel D+ OUT
  • Pin 2 = Channel D– OUT
  • Pin 3 = GND
CN8 — Power Input Header (4-pin, 2.54 mm pitch):
  • Pin 1 = +V (7–18 VDC)
  • Pin 2 = +V (7–18 VDC)
  • Pin 3 = GND
  • Pin 4 = GND
J1 — Enable+ Solder Jumper (back of PCB):
  • Closed = G pin tied to VCC (all channels enabled, active-high default)
J2 — Enable– Solder Jumper (back of PCB):
  • Closed = !G pin tied to GND (all channels enabled, active-low default)
PCB Files
The PCB layout in Figure 5 shows the silk screen top, bottom copper layer, and top copper layer. Board dimensions are 46.36 × 30.48 mm with four 3 mm mounting holes.
Figure 5. PCB layout for the AM26LS31 module: silk screen top, bottom
layer, and top layer.
Figure 5. PCB layout for the AM26LS31 module: silk screen top, bottom layer, and top layer.
Quadruple Differential Line Driver Gerber Files
You can download the layout files for this project here:
Except where noted, all images used courtesy of Rajkumar Sharma
