Analog Integrated Circuits
Logarithms for Analog Circuits
16 questions By Tony R. Kuphaldt
Page 1 of 6 0 of 16 answers revealed (0%)
  • Question 1 of 16
    The concept of a mathematical power is familiar to most students of algebra. For instance, ten to the third power means this:
    103 = 10 ×10 ×10 = 1000
    . . . and eight to the seventh power means this:
    87 = 8 ×8 ×8 ×8 ×8 ×8 ×8 = 2,097,152
    Just as subtraction is the inverse function of addition, and division is the inverse function of multiplication (because with inverse functions, one “undoes” the other), there is also an inverse function for a power and we call it the logarithm.
    Re-write the expression 103 = 1000 so that it uses the same quantities (10, 3, and 1000) in the context of a logarithm instead of a power, just as the subtraction is shown here to be the inverse of addition, and division is shown to be the inverse of multiplication in the following examples:
    3 + 8 = 11 ( andare inverse functions) 11 − 3 = 8
    2 × 7 = 14 (× and ÷are inverse functions) 14 ÷ 2 = 7
    103 = 1000 (powers and logs are inverse functions) log10 ??? = ???
    Reveal answer
  • Question 2 of 16
    Given the following mathematical expression, write another one defining a logarithm using the same variables:
    If: xy = z Then: log? ? = ?
    Reveal answer
  • Question 3 of 16
    Electronic calculators with logarithm capability have at least two different types of logarithms: common logarithm and natural logarithm, symbolized as “log” and “ln”, respectively. Explain what the difference is between these two types of logarithms.
    Reveal answer
