Analog Devices Isolated Gate Drivers | New Product Brief
Discover how this adjustable slew rate driver uses iCoupler technology to provide precision isolation.
New Product July 31, 2019 by Mouser
Analog Devices’ ADuM4122 Isolated Gate Driver is an adjustable slew rate driver that uses iCoupler technology to provide precision isolation. The ADuM4122 uses a high-frequency carrier and iCoupler chip-scale transformers to provide 5000Vrms of true galvanic isolation between input and output regions.
The architecture of the ADuM4122 also provides high immunity to common-mode transients, electrical noise, and magnetic interference.
The input side operates from a 3.3V to 6.5V input for compatibility with lower voltage systems, while the output side operates from a 4.5V to 35V supply. The output side features two 2A outputs, with one that can be set to a high impedance state, reducing the output slew rate for controlling EMI and voltage overshoot.
The ADuM4122 can operate with a junction temperature up to 125°C and has an integrated thermal shutdown.
  • 5kVrms true galvanic isolation
    • Based on Analog Devices iCoupler technology
  • High common-mode transient immunity: >150kV/µs
    • High immunity to electrical noise, magnetic interference
  • Supply voltages
    • VDD1: 3.3V to 6.5V
    • VDD2: 4.5V to 35V
  • Dual output pins
    • 2A peak current per pin
    • VOUT_SRC: can be set to high impedance to reduce slew rate, control EMI and overshoot
  • High junction temperature operation: 125°C
    • Integrated thermal shutdown sets outputs low
More Information
