TE Connectivity RJ45 w/PoE | Tech Specs
These Industrial Ethernet Jacks with Integrated Magnetics and PoE make design work easier.
New Product July 23, 2019 by TTI, Inc
TE Connectivity Industrial Ethernet Jacks with Integrated Magnetics and PoE make design work easier and provide excellent performance, all in an unassuming RJ45 jack.
The ethernet jacks with integrated magnetics and PoE are available for speeds up to 1 gigabit per second and comply with the IEEE 802.3at standard for PoE+, capable of delivering up to 25.5 watts per port to power remote devices. The new jacks also have integrated magnetics, eliminating the need for analog layout on the PCB, and a 3-wire choke prevents coil saturation and minimizes interference between power and signals.
The contacts have thick gold plating to improve corrosion resistance in harsh environments, and they have an extended operating temperature range up to 85 degrees Celsius for use in a wide range of industrial applications.
  • Complies with IEEE 802.3at (PoE+): up to 25.5W per port
  • Options for 10/100 or 1Gbps ethernet
  • Integrated magnetics for compact, simplified layout
  • Enhanced EMI with 3 wire choke
  • 30µinch gold plating prevents corrosion and electrical problems
  • -40°C to +85°C operating temperature range
More Information
