TE HV-20 High Volt Terminator Tooling | Tech Specs
New Product April 14, 2020 by TTI, Inc
The TE HV-20 High Volt Terminator Tooling is a benchtop tool that has an integrated vacuum to keep the connections clear of debris and can quickly terminate cables up to 120 square millimeters with 20 tons of crimp force. It’s also highly flexible, with a variable stroke rate and a rotatable die holder platform for processing from the left, front, or right side of the tool.
The HV-20 is also industry 4.0 ready, with USB and ethernet ports, a CQM II digital interface for crimp force monitoring, and multiple interlocks to keep operators safe.
  • Benchtop: 390kg, 552mm x 777mm x 974mm (width x depth x height)
  • Integrated vacuum keeps sensitive connections clean and clear of debris
  • Max wire size: 120mm2
  • Crimp force: 178kN (20T)
  • Flexibility: 1.3 to 8.3 second stroke rate, adjustable for processing from left, front, or right side
  • Industry 4.0 ready: USB ports, ethernet, CQM II digital interface for crimp force monitoring
More Information
