What Is a Switching Voltage Regulator?
Switching regulators are an essential circuit for efficiently generating stable supply voltages and for translating voltages up or down.
Technical Article July 14, 2023 by Robert Keim
Generating stable voltages capable of driving significant quantities of current is one of the fundamental tasks of electronic design. A basic model for a low-voltage electronic circuit goes something like this:
  1. A voltage with ample current-drive capacity is provided as one of the primary inputs to the system.
  2. This input voltage, which may be too high or too variable for direct use in the circuit, is converted into one or more regulated supply voltages whose magnitudes correspond to the specifications of the powered components.
  3. These components (microcontrollers, op amps, etc.) use the regulated supply voltages to perform the circuit’s required functionality.
There are various ways to accomplish this. When I first started designing circuits, I used linear voltage regulators—such as the venerable 7805—whenever possible. Nowadays, though, it is impossible to deny that switching regulators are often the superior method, and in my experience, they are usually the superior method.
In this article, we’ll discuss the nomenclature and then explore the basic principles of switching regulation.
Switching Regulator Terminology
“Switching (voltage) regulator” is perhaps the most common and recognizable term for denoting this class of circuit. However, you will also see various combinations of the following terms:
  • Switch-mode power supply (SMPS)
  • Switcher or switch
  • Converter or regulator
  • DC/DC
I actually prefer “switch-mode regulator” or “switch-mode power supply,” because “switch-mode” more successfully conveys the nature of these circuits: switching is the mode by which they accomplish their task of regulating or converting voltage.
All of these terms suffer from ambiguity that rarely causes problems but is nonetheless worth noting: “switching regulator” or “switch-mode power supply” could, in theory, refer to a circuit that generates a power rail using switches in conjunction with either an inductor or a capacitor.
Inductor vs. Capacitor-based Switch-mode Power Supplies
In practice, though, the terms mentioned above are reserved for inductor-based switchers. Figure 1 is an example of an inductor-based switching mode regulator. The vast majority of switch-mode power supplies are inductor-based. These will be the primary focus of this article.
Inductor-based switching power supply
Figure 1. Basic topology of an inductor-based switching power supply. Image (modified) used courtesy of Wikimedia Commons
Capacitor-based switchers, such as the example circuit of Figure 2, are typically called “charge-pump” power supplies or “switched-capacitor” power supplies. Figures 1 and 2 are both examples of circuits that produce an output voltage that is higher than the input voltage.
Capacitor-based switching voltage supply
Figure 2. Basic topology of a capacitor-based switching power supply.
Linear Voltage Regulation
Let’s now think about a linear regulator, as illustrated in Figure 3. Linear regulators can only reduce the voltage, so we know that the input voltage is higher than the output voltage.
Linear voltage regulation block diagram
Figure 3. Linear voltage regulation block diagram. Author's image
A linear regulator requires a small amount of current for operation; this is called the ground current. The ground current is often negligibly small, so let’s ignore it and assume that the current flowing into the regulator is equal to the current flowing out of the regulator and into the powered load circuit.
Now let’s think about power. We calculate electrical power as voltage times current, and since the output has equal current but lower voltage relative to the input, power must be lost somewhere. You can also imagine that the linear regulator is a simple resistive element with a voltage drop:
$$V_{DROP} = V_{IN} - V_{OUT}$$
In this case, the power dissipation of the linear regulator, PREG is:
$$P_{REG} = V_{DROP} \cdot I_{LOAD}$$
One of the components in a linear regulator is, in fact, a switch—not an electromechanical switch, but a transistor that is capable of functioning as a purely electrical switch. However, we don’t call a linear regulator a switching regulator because the switch is not turning on and off; instead, the switch is operating in an intermediate state in which it has a significant resistance, and this resistance dissipates power and allows for a reduction in voltage.
Linear regulation is simple and highly effective, but it is inefficient. The switch is operating in an intermediate, resistive state and dissipates potentially large amounts of power as heat. Unless you want your regulator to function as a regulator and an electric heater, this power is being wasted.
Switch-mode Voltage Regulation
This leads us to the concept of a switch-mode regulator. If we can keep the switch fully on or fully off—in other words, if we can avoid that high-power-dissipation intermediate region—we can create a much more efficient regulator. But our discussion of the linear regulator suggests that the wasted power is necessary for reducing voltage. What to do?
This is where the inductor comes in. An inductor stores and releases energy in such a way that the current through the inductor cannot change instantaneously. On/off switching action leads to an inductor current that gradually increases and decreases. When an inductor is combined with a capacitor, the resulting LC filter can smooth an on/off waveform into a relatively stable voltage. The magnitude of the smoothed-out voltage is determined by the on/off waveform’s duty cycle.
For example, let’s take a look at Figure 4. After filtering, different duty cycles (in this example, 10%, 50%, and 90%) correspond to different DC voltage levels (indicated by the red curves). These DC voltage levels are not perfectly flat because some ripple remains after filtering.
Switching regulator DC voltage as a function of PWM duty cycle
Figure 4. DC voltage levels as a function of the PWM duty cycle. Author's image
Thus, we can turn the switch on and off at a high frequency and then use pulse-width modulation and filtering to create the desired DC output voltage. We can also monitor a feedback signal and adjust the PWM duty cycle according to load conditions. This is the basic mode of operation in switching regulator circuits: inductive filtering for delivering consistent load current despite on/off switching action; feedback and PWM for regulating the voltage.
Even though the switch is operating at high frequency, it still spends most of its time in the low-power-dissipation states (i.e., the fully on and fully off states). This is why switching regulators can be so much more efficient than linear regulators.
Of course, there are many details and variations that I haven’t mentioned, but if you understand all this, you have a solid foundation for further study.
Example of a Switching Voltage Regulator Circuit: the Buck Converter
Figure 5 shows the basic topology of a buck converter, also known as a step-down converter. It uses switch-mode operation to reduce the magnitude of a DC input voltage. (Note that, strictly speaking, this is not a voltage regulator since it does not include the feedback subsystem required to maintain a stable voltage despite variable load conditions.)
The buck converter switching voltage regulator circuit
Figure 5. Example of a type of switching voltage regulator circuit: the buck converter.
In a future article, we’ll use the principles learned in this article to explore the behavior of the buck converter in detail.
  • S
    Sharpbakers July 21, 2023
    Nice article.  It’s been a while since I looked at Swtiching voltage regulators. So, a very nice refresher for me.  Thanks.
