Molex Brad Micro-Push M12 Cordsets and Connectors | Tech Specs
Molex Brad Micro-Push M12 Cordsets and Connectors are IP65 rated and easy to install, giving you just the protection you need, boosting operational efficiency, and lowering costs.
New Product May 30, 2019 by TTI, Inc
The push-on mating interface is backwards compatible with legacy M12 connectors, but reduces installation time by up to 80%, and the threadless coupling also eliminates reverse threading that may occur in high vibration applications.
The connectors and cordsets can carry up to 4 amps at 250 volts. They’re good for at least 100 mating cycles, and the use of a non-metallic coupler helps minimize costs and alleviates grounding and ESD concerns.
  • Push-on M12 interface with IP65 rating
  • Reduces installation time by up to 80%
  • Threadless coupling eliminates reverse threading in high vibration environments
  • 4A and 250V AC/DC max ratings
  • 100 mating cycle (min) durability
  • Non-metallic coupler alleviates grounding and ESD concerns
More Information
