Discrete Semiconductor Devices and Circuits
Design Project: Dual-output AC-DC Power Supply
5 questions By Tony R. Kuphaldt
Page 1 of 2 0 of 5 answers revealed (0%)
  • Question 1 of 5
    Safety is very important when designing and/or building a device powered by potentially lethal electrical sources such as residential AC line power. Explain how you can prove that the metal case of your power supply is indeed “grounded” for safety, such that an internal fault from one of the “hot” conductors to the metal case will result in a short-circuit that will trip the power receptacle’s fuse or breaker rather than shock the individual touching the case?
    Hint: a visual inspection is not good enough, and we don’t want to actually create a ground fault situation to test the grounding.
    Reveal answer
  • Question 2 of 5
    When connecting components together to build your power supply, it is important that you use the proper type(s) of wire. Identify what characteristics are required for the wires you use in this project, for each of the following parameters:
    Wire gauge:
    Insulation type:
    Stranding (solid or stranded):
    Reveal answer
  • Question 3 of 5
    How do we tell which winding of the step-down power transformer is the primary, and which is the secondary, without actually powering it up with AC line power? This is often an issue when students purchase cheap transformers that are unmarked and undocumented.
    Reveal answer
Related Tools:
