Discrete Semiconductor Devices and Circuits
Optoelectronic Devices
Question 1
In this circuit, the electric motor is supposed to turn on whenever the cadmium sulfide photocell is darkened:
Unfortunately, though, the motor refuses to turn on no matter how little light strikes the photocell. In an attempt to troubleshoot the circuit, a technician measures voltage between the collector and emitter terminals of the transistor with the photocell covered by a piece of dark tape, and measures full battery voltage. The technician also measures voltage between the collector and base terminals of the transistor, and measures full battery voltage. At that point, the technician gives up and hands the problem to you.
Based on this information, what do you suspect is faulty in this circuit, and how might you determine the exact location of the fault? Also, identify what you know to be not faulted in the circuit, based on the information given here.
Reveal answerThe battery, and its connections to the rest of the circuit, are in good condition. Also, we know that the motor is not failed open. In all likelihood, the transistor is not being “told” to turn on.
Notes:It is just as important for your students to be able to identify what is not faulted in a system as it is for them to be able to identify what is faulted. Replacing components that are not faulted is expensive and wasteful!
An essential part of answering this question is what the photocell does when light strikes it. Obviously, it undergoes a change in electrical resistance, but which way? This is something your students will have to determine before they can successfully troubleshoot the system. If they do not understand what the system is supposed to do, they will be helpless in interpreting what it is presently doing.
Question 2
Don’t just sit there! Build something!! Learning to mathematically analyze circuits requires much study and practice. Typically, students practice by working through lots of sample problems and checking their answers against those provided by the textbook or the instructor. While this is good, there is a much better way.
- Carefully measure and record all component values prior to circuit construction, choosing resistor values high enough to make damage to any active components unlikely.
- Draw the schematic diagram for the circuit to be analyzed.
- Carefully build this circuit on a breadboard or other convenient medium.
- Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
- Mathematically analyze the circuit, solving for all voltage and current values.
- Carefully measure all voltages and currents, to verify the accuracy of your analysis.
- If there are any substantial errors (greater than a few percent), carefully check your circuit’s construction against the diagram, then carefully re-calculate the values and re-measure.
When students are first learning about semiconductor devices, and are most likely to damage them by making improper connections in their circuits, I recommend they experiment with large, high-wattage components (1N4001 rectifying diodes, TO-220 or TO-3 case power transistors, etc.), and using dry-cell battery power sources rather than a benchtop power supply. This decreases the likelihood of component damage.
As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading” (on the high end) and to avoid transistor burnout (on the low end). I recommend resistors between 1 kΩ and 100 kΩ.
Reveal answerLet the electrons themselves give you the answers to your own “practice problems”!
Notes:It has been my experience that students require much practice with circuit analysis to become proficient. To this end, instructors usually provide their students with lots of practice problems to work through, and provide answers for students to check their work against. While this approach makes students proficient in circuit theory, it fails to fully educate them.
Question 3
The characteristically colored glow from a gas-discharge electric light is the result of energy emitted by electrons in the gas atoms as they fall from high-level “excited” states back to their natural (“ground”) states. As a general rule of electron behavior, they must absorb energy from an external source to leap into a higher level, and they release that energy upon returning to their original level.
Given the existence of this phenomenon, what do you suspect might be occurring inside a PN junction as it conducts an electric current?
Reveal answerPN junctions emit energy of a characteristic wavelength when conducting current. For some types of PN junctions, the wavelengths are within the visible range of light.
Follow-up question: what practical application can you think of for this phenomenon?
Notes:The practical application of this phenomenon should be obvious, and it is very commonplace in modern electronic equipment. Discuss with your students the energy-efficiency of this light emission as compared to an incandescent lamp.
Question 4
What determines the color of an LED?
Reveal answerThe type of semiconductor materials used to make the PN junction determine the color of light emitted.
Challenge question: describe the relationship between LED color and typical forward voltage, in terms of photon frequency, energy, and semiconductor band gap.
Notes:Ask your students to identify some common LED materials and colors, and of course cite their sources as they do. The challenge question may be readily answered through experimentation with different LED colors, although a physics-based explanation will take some additional research. This kind of experiment is very easy to conduct in class, together.
If time permits, you might wish to mention Albert Einstein’s contribution to this aspect of physics: his formulation for the energy carried by a photon (a quantum) of light:
E = hf Where,
E = Energy carried by photon, in Joules
h = Planck’s constant, 6.63 × 10−34 J·s
f = Frequency of light, in Hertz ([1/s])
Typical frequencies for visible light colors range from 4 ×1014 Hz for red, to 7.5 ×1014 Hz for violet.
Question 5
What is the typical forward voltage drop for a light-emitting diode? What is the typical forward current for an LED?
Reveal answerLED forward current is 20 mA. Forward voltage varies with color.
Notes:Be sure to ask students where they obtained their information, and what some of the forward voltage drops are for different color LEDs.
Question 6
Explain the operating principle of a photovoltaic cell, otherwise known as a “solar cell.” What happens within these devices to convert sunlight directly into electricity?
Reveal answerThe energy of photons (light “particles”) striking a PN semiconductor junction creates electron-hole pairs, which then move in the direction that the depletion region’s electric field pushes them.
Challenge question: of what significance is the band gap of the PN junction to the efficiency of the cell?
Notes:There is quite a bit of detail that could be added to the account given in the answer. Ask your students to supply some of this detail! There are many resources for learning how photovoltaic cells work, so your students should have no trouble finding the information on their own.
Question 7
What happens when external light strikes the PN junction of an LED? Design and operate an experiment to verify your hypothesis.
Reveal answerDid you really think I would reveal the answer to this question?
Notes:This makes an excellent in-class experiment, and demonstrates a useful property of LEDs that not many people know about.
Question 8
Photodiodes may be operated in either “photovoltaic” mode or in “photoconductive” mode. Describe the difference between these two modes, drawing schematic diagrams showing how a photodiode would be used in each mode.
Reveal answer
Notes:Ask your students whether a regular LED could be used as a photodiode in each of these modes. How would they set up an experiment to test an LED’s ability to act as a photodiode in each mode?
Question 9
Describe the function of a phototransistor. What typical applications do phototransistors have in circuits? What is the schematic symbol for a phototransistor, and how is it properly biased?
Reveal answerPhototransistors are used as light sensors, and also as electrically isolated switching elements when illuminated by LEDs.
Notes:Ask your students what point there would be in illuminating a phototransistor with an LED. Why not just dispense with the LED and just use a normal transistor to allow one electrical signal to control another?
Question 10
Photodiodes, phototransistors, and light-emitting diodes all play important roles in optical communications networks, where digital (on/off) signals are communicated over long distances as pulses of light energy rather than voltage or current.
Why are LEDs greatly preferred over other electro-optical devices such as incandescent lamps or gas-discharge bulbs? What can an LED do that a small electric lamp cannot?
Reveal answerSemiconductor-based light emitting devices are capable of turning on and off much, much faster than incandescent or gas-discharge devices.
Notes:In digital communications networks, speed is an essential quality. Ask your students why this is so, and by association, why semiconductor-based light sources are almost exclusively used in optical networks.
