Or try an example search: 3DES
OpenCores Reference Platform 2 (OCRP-2) is full-size length add-in PCI board. It includes two FPGA chips, video D/A and A/D converters, SDRAM…
OMRP (Openpattern Modular Routing Platform) is the first product-oriented project of the OpenPattern company. The target is to create a new open…
Overview This article describe the PCI express card with Xilinx Spartan 6 that i have made. The download section contains test applications in…
EUS 100LX is an "open" system board conforming to the PC104 format (90,2mm x 95,9mm) designed for industrial control and data acquisition…
Target of this project is development FPGA and/or FPGA powered real time audio DSP applications. This is Free (like freedom) Hardware project, a…
This is a small board with the low-cost ACEX FPGA with some SRAM and Flash. It is designed as a module for soft-core CPU development. I've used…
This project uses two off the shelf boards and interfaces them. The processor board used is a Olimex LPC-L2294 and the FPGA board is a Terasic DE1.…
A FPGA development board based on EP2C35F672, with SDRAM and flash .
Summary The Butterfly Light is an open source, modular FPGA development board. It is comprised of the USB Cocoon and the Spartan 3E Cocoon which…
The aes220 is a High-Speed USB 2.0 FPGA based on the Cypress FX2 micro-controller and Xilinx Spartan3AN (XC3S200AN or XC3S400AN) FPGA. The…
EUS FS is an "open" system board designed for industrial control and data acquisition applications. It is equipped with a 32-bit CPU…
Norwegian University of Science and Technology This project came to be because of the course "TDT4295 - Computer Design, Project", due to…
Griva Basic 1.2v - FPGA development kit ,, , Highlights , , , , , , , , , * Xilinx Spartan3E XS3S250E or XC3S500E -PQG208 , , , , , , , , , , , , ,…
The internal Logic state Analyser (LA) is a simplified version of a standard logic state analyzer, however it is build-in the prototyped circuit…
, [Keep It Simple,Stupid] Board. The board was evaluated like [or1k/orp project]. BOARD consists of two pieces. One is FPGA board.…
The IIE-PCI Development Platform board is a low cost PCI device card with a programmable logic chip (Altera ACEX), dynamic ram, and expansion…
Project to create generic emulator/debugger/analyzer with on-the-fly reprogrammable firmware on Artec Dongle II board (containing Altera Cyclone…
The MAXII-Evalboard is a small and simple board for learning VHDL und testing the own VHDL-codes on a real CPLD-hardware. For the first steps the…
OpenCores Reference Platform 1 (OCRP-1) standalone board was designed as a common prototype platform for testing our IP cores. It has a central…
Micro FPGA board is a stand alone, low cost, do-it-yourself board. All components are possible to get from a local electronics shop (with possible…
